After update my light is continuesly resetting:
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 64, in wrap_zigpy_exceptions
yield
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 84, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File “/usr/local/lib/python3.12/site-packages/zigpy/util.py”, line 131, in retry
return await func()
File “/usr/local/lib/python3.12/site-packages/zigpy/zcl/init.py”, line 377, in request
return await self._endpoint.request(
File “/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py”, line 265, in request
return await self.device.request(
File “/usr/local/lib/python3.12/site-packages/zigpy/device.py”, line 339, in request
await send_request()
File “/usr/local/lib/python3.12/site-packages/zigpy/application.py”, line 841, in request
await self.send_packet(
File “/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py”, line 810, in send_packet
raise ControllerError(“ApplicationController is not running”)
bellows.exception.ControllerError: ApplicationController is not running
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 239, in handle_call_service
response = await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 2738, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2779, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 975, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1047, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/light/init.py”, line 627, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File “/usr/src/homeassistant/homeassistant/components/zha/light.py”, line 360, in async_turn_on
result = await self._on_off_cluster_handler.on()
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 83, in wrapper
with wrap_zigpy_exceptions():
File “/usr/local/lib/python3.12/contextlib.py”, line 158, in exit
self.gen.throw(value)
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 75, in wrap_zigpy_exceptions
raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: ApplicationController is not running
Regards
Ruud
