after upgrade docker version to 27.2.1-1 in Debian 12, all USB devices cannot be locked by HA.
In case of Zigbee:
[23:24:12] INFO: Preparing to start…
[23:24:12] INFO: Socat not enabled
[23:24:13] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-09-13 23:24:14] info: z2m: Logging to console, file (filename: log.log)
[2024-09-13 23:24:14] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-13 23:24:14] info: z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-13 23:24:14] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d8d5972b999ced11a2d577faa7669f5d-if00-port0”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2024-09-13 23:24:14] error: z2m: Error while starting zigbee-herdsman
[2024-09-13 23:24:14] error: z2m: Failed to start zigbee
[2024-09-13 23:24:14] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-09-13 23:24:14] error: z2m: Exiting…
[2024-09-13 23:24:14] error: z2m: Error: Error Resource temporarily unavailable Cannot lock port
and I got the same error in the other USB device connected, one UPS system.
Do you have the same error?
