I’m trying to install Home Assistant Supervised on an Intel Atom 330 machine.
I’ve followed the installation guide and I managed to install debian 11 correctly. Network works (it downloads all the updates and the needed files without problem).
But after I give the last command:
dpkg -i homeassistant-supervised.deb
even after one hour I can’t get access to the User Interface…
So I tried the command:
sudo journalctl CONTAINER_NAME=hassio_supervisor
and I can find this error being repeated forever:
feb 16 16:55:11 homeassistant hassio_supervisor[19633]: 23-02-16 16:55:11 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-cli:2022.11.0: 500 Server Error for http+docker://localhost/v1>
feb 16 16:55:11 homeassistant hassio_supervisor[19633]: 23-02-16 16:55:11 WARNING (MainThread) [supervisor.plugins.cli] Error on install cli plugin. Retry in 30sec
I tried pinging microsoft.com or any other host but it does not work.
I also tried this:
root@homeassistant:~# nmcli c
NAME UUID TYPE DEVICE
Supervisor enp5s0 1c36050c-dfea-4115-b881-f678b8db12c7 ethernet enp5s0
root@homeassistant:~# nmcli c show "Supervisor enp5s0" | grep -i -e name_servers -e dns
connection.mdns: 2 (yes)
ipv4.dns: --
ipv4.dns-search: --
ipv4.dns-options: --
ipv4.dns-priority: 100
ipv4.ignore-auto-dns: no
ipv6.dns: --
ipv6.dns-search: --
ipv6.dns-options: --
ipv6.dns-priority: 100
ipv6.ignore-auto-dns: no
It looks like there are no nameservers set…
How can I solve?? As I said, the network worked perfectly until I installed homeassistant-supervised-deb
Thank you
