I dont now what to do after installing all depencies and updating them …I still get these errors and the frontend does not start …
Starting without “http:” in the configuration.yaml everything starts normal
Any help?
2018-01-07 15:16:56 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/etc/letsencrypt/live/xxxx.duckdns.org/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/etc/letsencrypt/live/macjex.duckdns.org/privkey.pem'. (See /home/homeassistant/.homeassistant/configuration.yaml, line 21). Please check the docs at https://home-assistant.io/components/http/
2018-01-07 15:16:56 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of api. Setup failed for dependencies: http
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not setup all dependencies.
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of websocket_api. Setup failed for dependencies: http
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not setup all dependencies.
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of system_log. Setup failed for dependencies: http
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not setup all dependencies.
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of frontend. Setup failed for dependencies: api, websocket_api, http, system_log
2018-01-07 15:16:57 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not setup all dependencies.
2018-01-07 15:16:59 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=32 from 2018-01-07 14:01:03.251003)
2018-01-07 15:16:59 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for dependencies: http
2018-01-07 15:16:59 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not setup all dependencies.
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for dependencies: frontend
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies.
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of media_player. Setup failed for dependencies: http
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: Could not setup all dependencies.
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of config. Setup failed for dependencies: http
2018-01-07 15:17:01 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not setup all dependencies.
2018-01-07 15:17:01 WARNING (Thread-21) [homeassistant.components.emulated_hue] When targeting Google Home, listening port has to be port 80
2018-01-07 15:17:08 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of conversation. Setup failed for dependencies: http
2018-01-07 15:17:08 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: Could not setup all dependencies.
2018-01-07 15:17:10 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2018-01-07 15:17:10 WARNING (MainThread) [homeassistant.setup] Setup of weather is taking over 10 seconds.
2018-01-07 15:17:11 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform dwd_weather_warnings is taking over 10 seconds.
2018-01-07 15:17:11 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2018-01-07 15:17:11 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2018-01-07 15:17:25 ERROR (MainThread) [miio.device] Unable to discover a device at address 192.168.178.40
2018-01-07 15:17:25 WARNING (MainThread) [homeassistant.components.light] Platform xiaomi_miio not ready yet. Retrying in 30 seconds.
2018-01-07 15:17:27 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform nmap_tracker
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 158, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/nmap_tracker.py", line 44, in get_scanner
scanner = NmapDeviceScanner(config[DOMAIN])
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/nmap_tracker.py", line 79, in __init__
self.success_init = self._update_info()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/nmap_tracker.py", line 105, in _update_info
scanner = PortScanner()
File "/srv/homeassistant/lib/python3.5/site-packages/nmap/nmap.py", line 131, in __init__
os.getenv('PATH')
nmap.nmap.PortScannerError: 'nmap program was not found in path. PATH is : /srv/homeassistant/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games'
2018-01-07 15:17:33 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8300: [Errno 98] error while attempting to bind on address ('192.168.178.29', 8300): address already in use
2018-01-07 15:18:02 ERROR (MainThread) [miio.device] Unable to discover a device at address 192.168.178.40
2018-01-07 15:18:02 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-01-07 15:18:02 WARNING (MainThread) [homeassistant.components.light] Platform xiaomi_miio not ready yet. Retrying in 60 seconds.
