After HA installation on RPI4 AddonManager.install blocked from execution
I want to use HA on my raspberry pi4. I installed HA via the raspberry pi imager. I am booting from SSD. My raspberry pi 4 is running and I have access to the HA via the browser on my normal PC.
The problem is that I could not install any add-on. I get the error message:
‘AddonManager.install’ blocked from execution, was unable to update plugin(s) cli and all plugins must be up to date first
Updates and repairs are not available.
I search for a solution and found that some people run the following commands:
ha su repair
ha core rebuild
ha host reboot
But where can I find the command line interface of HA ? I am a complete newcomer to HA.
Can anybody help me or have the same issue ?
Best regards
Dirk
Did you already reboot the Home Assistant host?
thank you for your reply. Yes I did this.
I installed everything again. It wokrs, now.
Best reagrds
Dirk
