how can i fix that - any ideas?
Did you read the release notes before you updated?
You need to change your individual devices config to the new format. There are examples in the documentation.
If you have trouble, post your card config as formatted text rather than a screenshot so we can help.
Thx for help! I checked some notes… Sorry for that i will keep in Mind to check everything… I Will try to solve it by myself now
can you help me please
type: custom:power-flow-card-plus
entities:
battery:
entity:
'0': b
'1': a
'2': t
'3': t
'4': e
'5': r
'6': 'y'
consumption: sensor.scb_home_power_from_battery
production: sensor.scb_pv_to_battery_power
state_of_charge: sensor.scb_battery_soc
color_value: true
color:
production:
- 254
- 251
- 65
consumption:
- 200
- 255
- 0
grid:
entity:
production: sensor.einspeisung
consumption: sensor.scb_home_power_from_grid
color_icon: true
color_circle: true
invert_state: false
secondary_info:
entity: sensor.scb_autarky_day
unit_of_measurement: '%'
icon: mdi:recycle
color_value: true
color:
consumption:
- 226
- 36
- 0
production:
- 118
- 187
- 64
solar:
entity: sensor.current_solar_total
display_zero_state: true
secondary_info: {}
color_icon: true
color_value: true
color:
- 245
- 236
- 0
home:
secondary_info: {}
individual1:
entity: sensor.go_echarger_210254_nrg_12
name: Tesla Model 3
clickable_entities: true
display_zero_lines:
mode: show
transparency: 50
grey_color:
- 189
- 189
- 189
use_new_flow_rate_model: true
w_decimals: 0
kw_decimals: 1
min_flow_rate: 0.75
max_flow_rate: 6
max_expected_power: 2000
min_expected_power: 0.01
watt_threshold: 1000
transparency_zero_lines: 0
title: PV-Anlage
Try asking here: Power Flow Card Plus 🚀 - #292 by phil9309
I don’t have a battery and am not sure how it should be configured.
i have the same issue. i read the readme, and couldnt see anything specific to this configuration change. Might be missing something, but a migration guide would be good
Advice is the same:
Hi! i hope you can help me ! after updating power flow card plus and reconfiguation the power flow card is working on the PC, on the IPAD and on the IPHONE of my wife… but not on my IPHONE, its still saying that im using an outdated configuration. i hope you can help me to fix this issue ! thank you
Sorry. No idea why that happens. It works on my phone. As I have said two times already, try asking in the main support topic.
@Presl1983 just delete the individuals part of your card and re-create them afterwards using the UI editor of this card.
