After I enables SSL via Duck DNS Interface not always rendering correctly
I have a strange problem.
I installed duckdns and a lets encrypt cert. Its been port forwarded and all is working well.
Except some CSS elements are not quite rendered the way it’s rendered when I visit the internal URL.
I.E Login box fields are kind of offset a little over the “Login” label. Its not a big deal just annoying.
any Ideas ?
Offset? Can you clarify with pics?
There could be 2 issues at play here:
  1. Most obvious would be your browser zoom settings based on the page
  2. You’re loading a different theme or front-end config, since most configs are stored locally based on url.
Thanks, I’m not sure what I did but its seems to be fixed now by it self. Maybe some CSS element didn’t download properly at the time.
