After import/configure node-red crashed
i use HOS and the Node-RED Add-on,
Few days ago i installed miele-node-red flow
If i add in this flow my Miele-account-data, a few minutes later crash my node-red…
I restore now already a older version but nothing helps…
if i look on my HOS-File-System i can’t find this config.js
any idea?
rror loading settings file: /etc/node-red/config.js
[17:42:51] INFO: Service Node-RED exited with code 0 (by signal 0)
[17:42:53] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
Error loading settings file: /etc/node-red/config.js
[17:43:00] INFO: Service Node-RED exited with code 0 (by signal 0)
[17:43:02] INFO: Starting Node-RED...
> start
[17:43:09] INFO: Service Node-RED exited with code 0 (by signal 0)
[17:43:11] INFO: Starting Node-RED...
> start
i removed now the Node-Red Add-on
and i installed again… but not start more
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 16.0.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.2  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2023.12.1
 Home Assistant Supervisor: 2023.11.6
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
[18:38:52] FATAL:
[18:38:52] FATAL: SSL has been enabled using the 'ssl' option,
[18:38:52] FATAL: this requires an SSL certificate file which is
[18:38:52] FATAL: configured using the 'certfile' option in the
[18:38:52] FATAL: add-on configuration.
[18:38:52] FATAL:
[18:38:52] FATAL: Unfortunately, the file specified in the
[18:38:52] FATAL: 'certfile' option does not exist.
[18:38:52] FATAL:
[18:38:52] FATAL: Please ensure the certificate file exists and
[18:38:52] FATAL: is placed in the '/ssl/' directory.
[18:38:52] INFO: Starting Node-RED...
[18:38:52] FATAL:
[18:38:52] FATAL: In case you don't have SSL yet, consider getting
[18:38:52] FATAL: an SSL certificate or setting the 'ssl' option
[18:38:52] FATAL: to 'false' in case you are not planning on using
[18:38:52] FATAL: SSL with this add-on.
[18:38:52] FATAL:
[18:38:52] FATAL: Check the add-on manual for more information.
[18:38:52] FATAL:
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service nodered: stopping
[18:38:53] INFO: Service Node-RED exited with code 256 (by signal 15)
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
i deaktivated SSL, now runs node-red
