I did a new clean installation of the latest version (10.5 on ODROID N2+) but it doesn’t seem to reboot without the memory card I installed it from. I thought it was installing it on the local storage (32GB).
Should the memory card not be finished with, and be removed ? Or does it need to stay in ?
I made the install image with balena etcher.
If you used balena to write the image onto the memory card, the memory card became your OS, and you internal drive remains unused….
You should write a stand alone, bootable ubuntu image onto the memory card and run balena from there to write the image to your internal drive
