Hello everyone,
i have set up the LDAP authentication as follows:
configuration.yaml
homeassistant:
auth_providers:
- type: command_line
command: /config/ldap-auth.py
meta: true
ldap-auth.py
#!/usr/bin/env python3
import os
from ldap3 import Server, Connection, ALL, core
SERVER = "ldaps://192.168.20.20"
USERDN = "uid={},ou=users,dc=example,dc=com"
BASEDN = USERDN
FILTER = "(objectClass=person)"
NAME_ATTR="uid"
ATTRS=[NAME_ATTR]
if 'username' not in os.environ and 'password' not in os.environ:
print("Need username and password environment variables!")
exit()
USERDN = USERDN.format(os.environ['username'])
BASEDN = BASEDN.format(os.environ['username'])
server = Server(SERVER, get_info=ALL)
try:
conn = Connection(server, USERDN, password=os.environ['password'], auto_bind=True)
#print("whoami: {}".format(conn.extend.standard.who_am_i()))
search = conn.search(BASEDN, FILTER, attributes=ATTRS)
if search:
#print("Search success: {}".format(conn.entries))
print(f"name=%s"%(conn.entries[0][NAME_ATTR]))
exit(0)
else:
print("LDAP bind succeded, but search yielded empty result")
exit(1)
except core.exceptions.LDAPBindError as e:
print(e)
exit(1)
Why do I only see a question mark at the bottom left of the dashboard? When I click on this I see the following text at the top: “You are currently logged in as”. The username is not passed. But I don’t know why?
Greetings from Stefan Harbich
