Hello community,
I have HomeAssistant running in a Docker on the Qnap. Due to a new QNap, I had to move Home Assistant. When I moved, I installed version 2021.11.1 and copied all my data from the old root directory into the new instance. After switching on I had to carry out the onboarding process and my configuration (view) is unfortunately all gone. The automations are still there. Can someone help me?
You probably forgot to copy the hidden files/directories. If you still have your original configuration, you can still copy them.
