Home Assistant:
- Core2023.12.4
- Frontend20231208.2
OS: Debian Linux
Docker container logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
^[[33m2024-01-07 10:16:01.237 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly^[[0m
^[[33m2024-01-07 10:16:01.495 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=2 from 2024-01-06 21:22:37.262879)^[[0m
^[[33m2024-01-07 10:16:10.242 WARNING (MainThread) [zeroconf] Error with socket 14 (('192.168.122.1', 5353))): [Errno 1] Operation not permitted
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 1190, in sendto
self._sock.sendto(data, addr)
PermissionError: [Errno 1] Operation not permitted^[[0m
^[[33m2024-01-07 10:16:10.265 WARNING (MainThread) [zeroconf] Error with socket 15 (('172.18.0.1', 5353))): [Errno 1] Operation not permitted
^[[33m2024-01-07 10:16:10.266 WARNING (MainThread) [zeroconf] Error with socket 16 (('172.17.0.1', 5353))): [Errno 1] Operation not permitted
These errors appeared after the PC was rebooted. Before that, everything was fine. Perhaps someone can suggest or point out a solution to the problem?
