After a restart or some time, I get the message: “Unable to load the panel source: /api/hassio/app/entrypoint.js.” when trying to access addons or supervisor, and, for instance, my NodeRed integration does not work anymore.
I run HASSIO as a Docker container on Ubuntu (running as a VM on my QNAP), see also the screenshot.
It is still version 2021.1.4 but I do not see an update prompt on the supervisor screen. The logs have some errors (attached below).
If I reload or restart the supervisor, I get the above message.
Can you help me? Might be fixed if I can update but I don’t know how.
21-01-20 21:17:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-01-20 21:17:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-01-20 21:31:06 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-20 22:01:12 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-20 22:10:28 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-01-20 22:17:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-01-20 22:17:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-01-20 22:20:05 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-01-20 22:20:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
21-01-20 22:20:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
21-01-20 22:20:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
21-01-20 22:20:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 67 all - 0 new - 0 remove
21-01-20 22:31:19 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-20 23:01:25 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-20 23:10:29 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-01-20 23:14:42 INFO (MainThread) [supervisor.host.info] Updating local host information
21-01-20 23:14:43 INFO (MainThread) [supervisor.host.services] Updating service information
21-01-20 23:14:43 INFO (MainThread) [supervisor.host.network] Updating local network information
21-01-20 23:14:46 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-01-20 23:14:46 INFO (MainThread) [supervisor.host] Host information reload completed
21-01-20 23:17:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-01-20 23:17:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-01-20 23:31:32 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-21 00:01:38 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-21 00:10:30 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-01-21 00:17:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-01-21 00:17:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-01-21 00:20:05 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-01-21 00:31:47 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-21 00:51:20 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
21-01-21 00:51:20 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-01-21 00:51:25 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-01-21 00:51:25 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-01-21 00:51:26 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-01-21 00:51:26 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-01-21 00:51:26 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
