Last week I had a hardware error where the solution was to get a new memory card and reinstall. So that’s what I did. This past weekend I reinstalled HA v0.97.1 and then I restored all of my configuration files.
Everything seems to be working except for most of my battery powered Z Wave devices. I say most because my 2 door locks work fine. All of the other battery powered devices are not showing up at all in any menu. It’s like the devices never existed.
I was wondering if there was a way to get these back because from what I understand, Z Wave devices are registered on the Z Stick which in my case is an Aeotec Z Stick.
Here is my log file…
2019-08-13 09:04:16 INFO (MainThread) [homeassistant.components.zwave] Z-Wave USB path is /dev/ttyACM0
2019-08-13 09:04:21 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2019-08-13 09:04:23 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-08-13 09:04:24 WARNING (MainThread) [homeassistant.components.lifx.light] LIFX no longer works with light platform configuration.
2019-08-13 09:04:24 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2019-08-13 09:04:27 WARNING (MainThread) [homeassistant.components.scene] Setup of platform lifx_cloud is taking over 10 seconds.
2019-08-13 09:04:32 INFO (SyncWorker_13) [homeassistant.components.zwave] Starting Z-Wave network...
2019-08-13 09:05:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 12 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 13 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 14 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 6 not ready after 31 seconds, continuing anyway
2019-08-13 09:05:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 6 Sensor (node_id: 6) not ready after 31 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 20 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 21 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 22 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 23 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 24 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 25 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 27 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 28 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 29 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 30 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 31 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 32 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 33 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 34 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:07 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 35 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:31 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 39 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:31 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 40 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 41 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 42 not ready after 30 seconds, continuing anyway
2019-08-13 09:05:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 43 not ready after 30 seconds, continuing anyway
2019-08-13 09:09:33 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
2019-08-13 09:09:33 INFO (MainThread) [homeassistant.components.zwave] final network state: 5 Driver initialised
2019-08-13 09:09:33 INFO (SyncWorker_4) [homeassistant.components.zwave] Z-Wave polling interval set to 60000 ms
2019-08-13 09:12:37 INFO (Dummy-5) [homeassistant.components.zwave] Z-Wave network is ready for use. All awake nodes have been queried. Sleeping nodes will be queried when they awake.
