I just got time of use so power between midnight and 6 is a flat rate of 8c.
The rest of the time it is 32.197 cents.
I have a few things on my dashboard that were calculating daily cost, weekly cost, monthly cost etc for the power.
Now I have to re-engineer these a bit, or delete them and just us the built in energy graph I guess - which I may do if this is all too hard.
I found a nice snippit of yaml to set sensor for the current cost (Current Electricity Tariff Cost) based on the time of day -
- name: "Current Electricity Tariff"
unique_id: Current Electricity Tariff
state: "{{ 'peak' if today_at('06:00') < now() < today_at('23:59') else 'offpeak' }}"
- name: "Current Electricity Tariff Cost"
unique_id: "Current Electricity Tariff Cost"
unit_of_measurement: AUD/kWh
state: >
{% set tariff = { "peak": 0.32197, "offpeak": 0.08 } %}
{% if now().hour <6 %}
{{ tariff.offpeak }}
{% else %}
{{ tariff.peak }}
{% endif %}
But I have no idea how to build this in for my other things I have on the dash, I have a few but lets concentrate on just one, then I can retrofit the others from it if anyone can help -
I have a utility meter (created in helper) called ‘Daily Imported’. It is using ‘Energy Imported’ as the input sensor and is set to reset daily. I have looked at creating a new one to replace this and the tariffs seem to be the way to go for this.
Unfortunately, I had a stroke some time back and I am not quite getting the process here to use these tariffs. Do they in some way reference the ‘peak’ and ‘offpeak’ I setup in the above yaml ?
Thanks.
