Hi all.
I’ve created a ‘bedtime’ automation and was hoping to add all the little bits into one automation a few separate ones.
So basically this is what I’m wanting to happen.
When I press my button at night I want it to turn some things off straight away and set the house alarm (through mqtt) but leave the Dining room lamp on until until the Living room door changes to closed and the alarm sensors state is also ‘Part Set’ (it takes about 10 seconds for my house alarm to set)
When I close the living room door the lamp should then go off if the alarm is set or wait until they both are.
Then I want it to wait 10 mins and when the power drops below 35w on my smart plug upstairs turn the plug off , so basically if I watch some TV in bed and put the TV box and TV onto standby.
I’ve tried all sorts of if conditions etc I just can’t get it to do that, it either doesn’t turn the lamp off or turns the lamp off when the a look arm sets even if the doors open.
This is my code thanks for any help.
alias: "Bedtime "
description: ""
triggers:
- domain: mqtt
device_id: c53751c9aefbf2790d22b6401aa47813
type: action
subtype: toggle
trigger: device
alias: Ikea button pressed
conditions: []
actions:
- parallel:
- action: mqtt.publish
metadata: {}
evaluate_payload: false
qos: "2"
retain: false
topic: selfmon/vmod.010faa/vkp/key
payload: MYPAYLOAD
alias: Set alarm
- alias: Turn room lights off
action: light.turn_off
metadata: {}
data: {}
device_id:
- e8c8e8c34ae24dfea8aea303fb5c670f
- 46006cd0e908151971db1db52d88f1c5
entity_id: light.outdoor_leds
- action: media_player.toggle
metadata: {}
data: {}
device_id: 168bd975df730dab0223ef13fbd983b4
entity_id: media_player.octagon
alias: Turn off tv and box
- wait_for_trigger:
- trigger: state
entity_id:
- binary_sensor.living_room_door_contact
to: "off"
- trigger: state
entity_id:
- sensor.flex_status
to: Part Set
timeout:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- delay:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
- wait_for_trigger:
- trigger: numeric_state
entity_id:
- sensor.bedroom_tv_power
below: 35
- action: switch.turn_off
metadata: {}
data: {}
device_id: 7767edb7d836ba25907e20299c59aa49
mode: single
