I have just updated HA to 2023.5.2 on my Odroid C4 with dietpi. After the update did HA launch but with the error
The following integrations and platforms could not be set up:
cloud (Show logs)
assist_pipeline (Show logs)
mobile_app (Show logs)
default_config (Show logs)
Please check your config and logs.
Now will I provide some logs
log default_config
Logger: homeassistant.setup
Source: setup.py:204
First occurred: 17:43:26 (1 occurrences)
Last logged: 17:43:26
Unable to set up dependencies of default_config. Setup failed for dependencies: assist_pipeline, cloud, mobile_app
Source: setup.py:206
Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: assist_pipeline, cloud, mobile_app')
Log mobile_app
Logger: homeassistant.loader
Source: deps/lib/python3.10/site-packages/webrtcvad.py:8
First occurred: 17:43:01 (3 occurrences)
Unexpected exception importing component homeassistant.components.cloud
Unexpected exception importing component homeassistant.components.assist_pipeline
Unexpected exception importing component homeassistant.components.mobile_app
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/loader.py", line 813, in get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/components/cloud/__init__.py", line 36, in <module>
from . import account_link, http_api
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/components/cloud/http_api.py", line 19, in <module>
from homeassistant.components import assist_pipeline, conversation, websocket_api
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/components/assist_pipeline/__init__.py", line 25, in <module>
from .websocket_api import async_register_websocket_api
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/components/assist_pipeline/websocket_api.py", line 30, in <module>
from .vad import VoiceCommandSegmenter
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/homeassistant/components/assist_pipeline/vad.py", line 4, in <module>
import webrtcvad
File "/mnt/dietpi_userdata/homeassistant/deps/lib/python3.10/site-packages/webrtcvad.py", line 8, in <module>
__version__ = pkg_resources.get_distribution('webrtcvad').version
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/pkg_resources/__init__.py", line 514, in get_distribution
dist = get_provider(dist)
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/pkg_resources/__init__.py", line 386, in get_provider
return working_set.find(moduleOrReq) or require(str(moduleOrReq))[0]
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/pkg_resources/__init__.py", line 956, in require
needed = self.resolve(parse_requirements(requirements))
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/pkg_resources/__init__.py", line 815, in resolve
dist = self._resolve_dist(
File "/home/homeassistant/.pyenv/versions/3.10.9/lib/python3.10/site-packages/pkg_resources/__init__.py", line 856, in _resolve_dist
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'webrtcvad' distribution was not found and is required by the application
Source: setup.py:214
Setup failed for cloud: Unable to import component: Exception importing homeassistant.components.cloud
Setup failed for assist_pipeline: Unable to import component: Exception importing homeassistant.components.assist_pipeline
Setup failed for mobile_app: Unable to import component: Exception importing homeassistant.components.mobile_app
All the other logs look like the same to those logs. I have already checked if The ‘webrtcvad’ distribution was installed but it was and I also removed it and reinstalled it but it doesn’t work. Does anyone know how to fix this? If you need more info don’t hesitate to ask.
