Hi Every one, I am for the first time at this forum, because is the first time I can’t find a solution.
Lat me give the full problem:
I had a server with hass.io on it but because of some strange thing it broke and I change it to a new Intel-Nuc, install the image and restor my settings no problem.
after that everything went as normal thil the update 2021.3 came ( a day after).
It seams that my starting up my heater don’t work any more the temperatur drops and the heater sould start but it do not, strangely if i activate it by hand , when it met the temp it shut met it turn it of without any problem.
I am so confuse because it is not in the list of broken update so i cant find the way to fix it.
I even deleted my old automation and remake a new one and on a different way but still noting.
- id: '1614968481208'
alias: Warming Up
description: Warming the hous up to a good temperature
- platform: numeric_state
entity_id: sensor.temperature_2
below: '21'
condition:
- condition: time
after: 07:00
before: '20:00'
- condition: state
entity_id: input_boolean.notify_home
state: 'off'
- service: switch.turn_on
entity_id: switch.lanswitch1
mode: restart
the supper strange thing is that after i do the first turn on manually it keep doing the automation till the next day.
the problem i could find is this:
2021-03-06 08:17:17 WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error initializing 'Warming Up' trigger: In 'numeric_state' condition: entity sensor.temperature_2 state '°C' cannot be processed as a number
Still strange as I did not change that in the past
That looks odd, do you know why the state is °C rather than a number? What is the state of sensor.temperature_2 state when you look at the entity in the States view in Developer Tools?
It’s it under 21 when it gets to 7am, if so it will never trigger.
You should really replace this automation with a generic thermostat, and have automations or use scheduler to set the target temperature according to a schedule
When you check history for sensor.temperature_2 do you see temperature where it reported below 21? Basically sensor reporting temperature at correct intervals etc?
Also, if you goto automation tab you will see the time when each automation was triggered last (Does not mean it worked or running correctly just that trigger worked)?
the thing I cant figurout is that it was working fine and it work fine after the morning manually turn it on.
and in the past with the old hass.io i never had a problem , is there somthing i am missing in the new one?
its not only checking the History, as I said before if i start the heater manually(turning it on in hassio) the turning of automation will work and after that first time i do that it will work the rest of the day till the next day when its 7 a clock again i need to do it manually its like he dont know what to do till when I show him/it.
Do it have to do with the new setting of the starting state?
my switch dont send a status as it is a command-line switch:
The only 2 thing that change is that i have now a Nuc with hassos instead of hassio on generic linux and the hassio is updated ( whitch is normaly good), but I cant find out where to thel the automation ignore the state of the switch ( if that is the problem).
still is strange that after I turn it on hassio will take over after word for that day (24hours) (looks like hass.io see the state)
so it have to do with the new faile-safe setting from hassio 2021.3?
but then is a litle problem because if you do a update your Home assistant will resaart meaning the automation will not work , what explain to why it dont work after the update and every thime i toucht i did something wrong and adjust things and reboot… what is a option for doing this than ?
I cant find the way to do the generic thermostat what was said before, its a zigbee temp-sensor I dont know if its possible ore how to do it ( could not find it ).
It will only miss if the temperature drops below 21 right as you reboot. I don’t think that will be a problem but you can additionally trigger on startup if you want to be really sure.
Also, you have a time condition … so if the temperature is already below 21 at 7:00 I guess it will never execute until you manually bring the temperature above 21. That might be your actual problem. You can fix this with an additional time trigger which has a condition on the current temperature.
(I am still miffed by the warning though, something seems off there)
An automation would be used to control when climate.house is enabled (07:00) and disabled (20:00). While it is enabled, it automatically maintains the temperature at 21 within a tolerance of 0.5 degrees.
