I updated this morning to 2023.6
But some of my automations are not working anymore.
For example, I have a button whit 1press 2 press and long press.
If i look to the automation it sees it correctly. It mention that it is triggered. But nothing happens.
If i press on start action, in the action list. than all works correclty
Like you see here, It says it is triggered. but the first part is not starting. when you press the 3 balls inaction and than play (uitvoeren) it works, it switch the plug from on/off or off/on.
Other place it also working.
strangly it is only whit the button. on other place whit pressence sensor that works correctly. turns on light and after 10min it goes out. that is how I made the automation
what has changed to get this issue
