After updating to 0.81 all of my MQTT devices (locks, lights, sensors, etc) are showing the yellow “entity not found” error in Lovelace and nothing appears on the states screen. I have since rolled back to 0.80.3 and everything is back to normal. I didn’t see any MQTT breaking changes. What am I doing wrong here?
Edit: just attempted to update again, and it’s working just fine. Not sure what happened.
Looks like in 0.81.0 you cannot have both manually configured MQTT devices and auto-discovered MQTT devices. I use a mix of both, and all of my manually configured ones disappear when I have discovery set to true. I cannot tell from the release notes if this is the intended functionality now though?
Same here. My esphomeyaml devices are fine, but my SmartThings MQTT Bridge devices all disappeared. I even tried manually adding entity_id references without any luck. I’ve got an issue open here if you’d like to add to it.
FYI on this: #17935. Apparently there’s a bug where some components prevent others from loading. In my case it was octoprint. Everything came back once I commented that out.
