After upgrade HA lost the Lovelace menu bar
After upgrade HA lost the Lovelace menu bar.
Any idea?
Same from here, no menu bars, cant do anything. Did you find a solution?
If you are using Custom Header or anything similar to that, you will need to upgrade it to the latest version.
Bu the Custom Header is in the HACS. HACS does to offer any upgrade. And I can"t find the Custom Header in the HACS at all…
Solution:
find the lovelace_resources file in .storage directory
change the url to /hacsfiles/… to /community_plugin/…
You should never manually edit the files in .storage.
If you ever need to disable Custom Header to access hidden UI elements look anywhere CH is mentioned (CH forum post, CH github readme, CH docs, CH important notes, CH editor).
The first warning in all these places will tell you how to temporarily disable CH ( add ?disable_ch to your URL).
Your resources are located in and can be edited in Configuration > Lovelace Dashboards > Resources.
Also, this is quite confusing:
Your resources URL should look like this for Custom Header:
/hacsfiles/custom-header/custom-header.js
Sorry for bumping this, but this should be cleared up for anyone finding this.
today i lost the menu bar again after restarting the HA.
Can you help me, how to solve it?
Thank you
Did you follow any of his recommendations for disabling it?
That’s very little information to go on. I would suggest either submitting an issue to Github with as much of the information requested from the issues section of the docs as possible or, at the very least, provide that info here.
This should also probably go in the Custom Header thread as things would get very messy if every issue was a new topic.
After I cleared the docker and restarted the menu appeared again. Thank you
