After upgrade to 0.116.4 miflora sensors not working (bluetooth polling error)
After upgrading to Hassio 0.116.4 i cannot poll any data from my miflora sensors. The sensors are displaying: unavailable. After debugging i have found that Hassio was not able to poll data from the sensors. Please see the log of 1 sensor below:
2020-10-20 22:14:34 DEBUG (SyncWorker_43) [homeassistant.components.miflora.sensor] Polling data for plant1 Temperature 2020-10-20 22:14:34 INFO (SyncWorker_43) [homeassistant.components.miflora.sensor] Polling error BluetoothBackendException: Could not read data from Mi Flora sensor XX:XX:XX:XX:XX:X
Am i only experiencing this problem? I have searched the forums and Git but cannot find this problem. (only found an older issue:https://github.com/home-assistant/core/issues/30275). Does anyone know how to resolve this problem?
Thank you!
Hey, can confirm that after the Update, generally Bluetooth integrations stopped working. In my case not only miflora, but also EQ3bt thermostats and Mijia Temperature sensor. Haven’t found out yet what the problem is.
see issue/pull-request in Github that might be related to this:
(edit:)
Downgrading to 4.13 solves the problem for me for the moment, next release will include the fix as far as I understood Github.
Hi, thank you. I will downgrade as well.
Is this issue still ongoing? Just got one and no sensor data coming thru. Any suggestions appreciated.
