I’ve updated my ESPHome integration to v1.16.0 yesterday and updated one of my Sonoff basic devices.
Update went fine until it rebooted.
Since then the sonoff is constantly rebooting and connecting to my Wifi for about 5 seconds and then jump into the fallback AP mode. And then, reboot once again.
I’ve tried connecting to it, but it’s not online long enough to do anything
When it ran on 1.15.3 it functioned perfectly and my OCD has caused me to fall down the rabbit hole of unverified updates
My config:
substitutions:
devicename: achtertuin_licht
upper_devicename: Achtertuin Licht
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'Domotica'
password: 'xxxx'
ap:
ssid: "Achtertuin Licht Fallback"
password: "xxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: xxx
ota:
password: xxx
# Uptime sensor used in following formatted uptime sensor
- platform: uptime
name: "Achtertuin Licht Do Not Use"
internal: true
update_interval: 600s
# WiFi Signal sensor.
- platform: wifi_signal
name: Achtertuin Licht WiFi Signal
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: Achtertuin Licht ESPHome Version
# Sensor to display uptime in Days/hours/minutes
name: "Achtertuin Licht Uptime"
lambda: |-
uint32_t dur = id(achtertuin_licht_do_not_use).state;
int dys = 0;
int hrs = 0;
int mnts = 0;
if (dur > 86399) {
dys = trunc(dur / 86400);
dur = dur - (dys * 86400);
if (dur > 3599) {
hrs = trunc(dur / 3600);
dur = dur - (hrs * 3600);
if (dur > 59) {
mnts = trunc(dur / 60);
dur = dur - (mnts * 60);
char buffer[17];
sprintf(buffer, "%ud %02uh %02um %02us", dys, hrs, mnts, dur);
return {buffer};
icon: mdi:clock-start
status_led:
pin:
number: GPIO13
inverted: yes
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- light.toggle: achtertuinlicht
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: relay
switch:
# Switch to restart the Sonoff.
- platform: restart
name: Achtertuin Licht Switch Restart
web_server:
port: 80
Is this newer firmware heavier than the previous one and it’s crashing due to too much being enabled? Or is there a bug somewhere?
