After installing 0.92 some Zwave devices becomes unavailable. I dont see the nodes in the Zwave console. This problems occured the first time a week ago after updating my Pi and HASS to 0.91.4. I also noticed that the nodes which are recognized are named different (from sensor.neo_coolcam… to sensor.shenzhen…) I read that this had to do with a change of the openzwave package.
so I tried to fix the unavailable nodes to reset all the zwave devices (aotec stick, extender and all battery sensors). After adding all the nodes everything works fine…till now.
It seems that I’m back to the original problem someone an idea??
I get the following messages:
homeassistant log
Z-Wave node 5 not ready after 30 seconds, continuing anyway
Z-Wave node 7 not ready after 30 seconds, continuing anyway
zwave log
2019-04-25 23:36:10.469 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x71
2019-04-25 23:36:10.492 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0x00, 0x0c, 0xcf
2019-04-25 23:36:10.492 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x30
2019-04-25 23:36:11.875 Detail, Node005, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x05, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x7c
2019-04-25 23:36:11.875 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x71
2019-04-25 23:36:11.897 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x30
2019-04-25 23:36:11.897 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x30
2019-04-25 23:36:42.978 Detail, Node005, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x05, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x01, 0x08, 0x61
2019-04-25 23:36:42.979 Detail,
2019-04-25 23:36:42.979 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x71
2019-04-25 23:36:43.001 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0x00, 0x0c, 0xcf
2019-04-25 23:36:43.001 Info, Node005, ApplicationCommandHandler - Unhandled Command Class 0x30
2019-04-25 23:36:49.114 Detail, Node007, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x07, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xf1, 0x10
2019-04-25 23:36:49.114 Info, Node007, ApplicationCommandHandler - Unhandled Command Class 0x31
