Again error in yaml
again the yaml code seems to be corrupt. I copied it from the website: Home Assistant Müllkalender einrichten ♻️
This ist my yaml code:
waste_collection_schedule:
  sources:
    - name: jumomind_de
      args:
        service_id: mymuell
        city_id: 71133
        area_id: 760
  # ------- Garbage Collection -------
  # next collection
  - platform: waste_collection_schedule
    name: "Nächste Abholung"
    value_template: '{{value.types|join(", ")}}{% if value.daysTo == 0 %} Heute{% elif value.daysTo == 1 %} Morgen{% else %} in {{value.daysTo}} tagen{% endif %}'
  # Nächste Restmüll-Abholung
    types:
      - Restmüll
  # Nächste Biomüll Abholung
    types:
      - Bio Müll
  # Nächste gelber-Sack Abholung
    types:
      - Gelber Sack
  # Nächste Papiermüll Abholung
    types:
      - Papiertonne
Error Message from Homeassistant:
Cannot quick reload all YAML configurations because the configuration is not valid: Invalid config for [waste_collection_schedule]: [sensor] is an invalid option for [waste_collection_schedule]. Check: waste_collection_schedule->waste_collection_schedule->sensor. (See /config/configuration.yaml, line 286).
Can someone help me? I searched really a lot…
thanks
Shouldn’t that be:
  # next collection
In yaml (and Python) the spacing is critical. trypically in a section where a word ends with a colon, the following lines are indented at least two spaces from the one above (?)
When you are in the file editor, did you look to the upper right corner to see if there was a red exclamation point (which shows if the alignment is incorrect)?
Nope. As long as the spacing is consistent in each block any number of spaces is valid. Two is just convention. These are both valid:
This is not:
Shouldn’t sensor: be inline with waste_collection_schedule: ? (assume this is your configuration.yaml)
  sources:
    - name: jumomind_de
      args:
        service_id: mymuell
        city_id: 71133
        area_id: 760
  # next collection
    types:
      - Restmüll
    types:
      - Bio Müll
    types:
      - Gelber Sack
    types:
      - Papiertonne
Yeah. That is the issue. I was looking up the docs to check but got distracted with other topics.
Thanks for the tip (there was misalignment though, I just had the wrong spot!)
Nothing works.
The confusing thing for me is, that in the upper right corner is a green hook. So everything seems to be ok for the yaml editor. But when i wan´t to restart there ist the error (see above)
Thank you for help… Any other ideas?
