Hello everyone,
i have a sensor called ‘sensor.unimatrix_1_pv_input_power’ that get updated quite frequently and displays the PV power of my inverter. With the PI30 protocol i don’t have a daily production value so i’m using the PV power to calculate it but i get totally wrong values. In few minutes of run it goes over the whole day of production. I tried also the net options but i really don’t understand what i’m doing wrong. Where i can start to debug what’s happening?
Thank you a lot for the suggestion. Yes, my sensor works with W, it’s the instant read-out of the inverter in that exact moment. I don’t understand the part “definition etc etc”. I used the GUI to create it, it asked from wich sensor make the utility meter and when to reset. I have selected daily at 00:00.
Now that i read about the Integration, things makes sense. I tought that since it’s an utility meter, it automatically converts W → Wh.
Now i play a little bit with the integration and i will keep you updated.
Thank again.
Sorry if took me so much to reply. With your suggestion it’s working well. Now i will remember to use the rienmann sum integral before to create the utility meter.
