Hi all,
last week I started with installation acc. ‘Getting started…’ on HomeAssistant.io.
I am new in things like Rasperry and SSH, but generally have technical background.
So I do still have some hope to get the system up and running…wireless
- Rasperry Pi 3B+
- 32bit Image
- SD Card 32bit flashed
- USB Stick FAT 32 formatted
- Folder network/ created
- file ‘my-network’ added , UNIX / ANSI coding (checked via Notepadd plus plus)
I have access via SSH addon to the ‘configuration.yaml’ file via Notepad plus plus.
The Frontend is vailable via Ethernet.
My Wifi is running with WPA2.
The ‘my-network’ file includes following:
[connection]
id=my-network
uuid=72111c67-4a5d-4d5c-925e-f8ee26efb3c3
type=802-11-wireless[802-11-wireless]
mode=infrastructure
ssid=FxxxE
#Uncomment below if your SSID is not broadcasted
#hidden=true[802-11-wireless-security]
auth-alg=open
key-mgmt=wpa-psk
psk=lxxxxxx4[ipv4]
method=auto[ipv6]
addr-gen-mode=stable-privacy
method=auto
Is there any chance to check, if the USB stick has been recognized?
I have no separate screen available at the moment to directly connect to the Raspi. Is that required?
I hope someone can bring some light in and identify my fault in configuration…
Greets
Jörg
