I am currently trying to get my water sensor to trigger an alarm on my phone. I do receive a push notification, but there is no real “alarm”.
I am using the HA app with an Android phone.
I have set the configuration for the notification in the same way as in the documentation. However, only a push notification appears and no real alarm. I want my phone to ring aggressively even in silent mode.
service: notify.mobile_app_sm_g980f
message: Wasser Sensor Küche ausgelöst
title: "Warning: Water leak"
ttl: 0
priority: high
channel: alarm_stream
according to the manual on GitHub there is also an alternative way to write this code, talking about beta users. It may be, that the documentation is out of date and that method has become standard now?
i have found out so far that without alarm stream i get a vibration and a ringing like a message.
with alarm_stream it becomes just the ringing like a message and with alarm_stream_max it is the alarm clock alarm.
But none of this bypasses silent mode. when my phone is set to vibration only, nothing comes.
Also it is just a ring, not an alarm over 30sec or something like this.
So I just tested this on my mobile, with volume up, with volume max down, with vibration only, with do not disturb mode. In all these possible settings it works fine. The settings are ignored and sound is coming thru.
With text message and also with TTS message.
So the code from that manual seems to be valid.
I’m testing on OnePlus 6T device with Android 11
alarm_stream → alarm till i stop it, not working when in vibration only mode
alarm_stream_max → just a ring, also not working in vibration mode
beta_settings - > not working at all
I’m using a Samsung Galaxy 2020 with Android 12.
If you check your notification channels in your app, does it create new channels?
For me, it does, so maybe the channels got different names in the german OS.
Also Max seems to be less aggressiv then without max
I see your are using a Samsung device. Not all those device support this feature, Samsung deliberately changed that to prevent sound. Nothing the app can do unfortunately.
Make sure TTS is installed on the device and you can play the sample sound in device settings. Also make sure Google speech services is up to date and the default engine.
Go to your device settings and check text to speech and make sure the sample can play, if not then make sure Google Speech services is installed and the default. May also need to download a language if not already done.
For your device, no it doesn’t seem like the manufacturer allows it. You’ll need to use a workaround to take your device out of silent/ do not disturb and then place it back once done.
- service: notify.mobile_app_sm_g980f
message: command_volume_level
title: "90"
channel: ring_stream
message: Help
title: Help
ttl: 0
priority: high
This will push the vol up before the notification. Seems to work for Galaxy 20.
Is there a way to change the actual sound? Right know it seems to be my alarm sound.
But in the HA App itself i only can pick short sounds.
Maybe i just don’t understand your awnswer.
But in the app it only allows me to change to a notification sound, not to an alarm sound.
Or is there a different way to change the channel sound?
changing the channel sound is an android thing, some devices may let you upload a different sound but thats up to the device and out of control of the app. Its an android setting.
