The app aidoo for by airzone has no integration in HA, and I think that is a standart to integrate.
I only found a man who integrate airzone by modbus cable, but if the airzone has WiFi I spouse the integration should be more easy
Thank you.
Thank you.
I have it too and I want a full integration with HA.
I do not understand why Airzona does not release the API.
Hello, I totally agree. This integration would open a real range of possibilities, since Aidoo integrates with practically all air conditioners, both splits and ducts. Is there any possibility in this regard?
This is the only project I’ve found, but as I said in my first post you need to connect a raspi zero by modbus with the airzone module
Hi! one more here!! Aidoo Integration in HA please!
Through the cloud GitHub - max13fr/Airzonecloud-HomeAssistant: Airzone Cloud plugin for Home Assistant
It stopped working!
It’s not working at all
I am in the market for a new split system. I was looking at the Airdoo Pro. It apparently allows connection of a normal thermostat - so was going to add an Ecobee and use the automation for that. This seemed like the most reliable/easiest way to make this work. Definitely more expensive because of the addd cost of the thermostat - but that would give nice local control on the wall.
Or am I missing something?
There is a great local API integration manual over at this page. Would that help?
I’m using the standard Airzone integration and it’s working fine with my Aidoo Pro’s over their IP address.
