AiDot and " OREIN Smart Motion Security Light"
I recently bought an “Orein Smart Motion Security Light” partly because a Mr Bruce R Cleghorn wrote in a positive review on Amazon that “it Integrates with Home Assistant perfectly”.
It works perfectly with the AiDot app on Android on the same network.
I have added the “AiDot Home Assistant Integration” version v1.2.0 via HACS and I have set up the integration with my country, username and password. The integration found my light with the name I had given it in the AiDot app (Stable Door Security Light)
I have a new light icon with a switch in my HA overview.
This switch kind of controls the light.
The first time I slide the switch to the “on” position the light comes on, but a few seconds later the switch turns “off” but the light stays on for the pre-set 30 seconds.
Subsequent attempts to turn the light on usually works but produces an error message:
Failed to perform the action light/turn_off.light.stable_door_security_light (<class ‘custom_components.aidot.light.AidotLight’>) set to unsupported color mode rgbw, expected one of {ColorMode,BRIGHTNESS:‘brightnes’>}
The only way I have found to turn the light off is do so during the two seconds or so that the swich stays in the “on” position.
I am trying to control the light using node-red. Within the HA Action node I am using Action light.turn_on and light.turn_off this works occasionally. To turn the light off I have send a turn on immediately followed by a turn off.
Has anybody got (other than Mr Cleghorn ) got this working properly. I am quite new at this and may have misunderstood things. Thanks for any help.
How long ago?
Maybe your integration is outdated?
Does this help?
Did you ask that person for tips? I haven’t heard of
Sounds like it could be Tuya with a random made up manufacturer name.
Does it respondf to the Tuya SmartLife App?
Reviewed in the United Kingdom on 23 January 2026
No it is from AiDot and (as I said) works perfectly with their Android app, and it works partially with the AiDot HA integration.
I was hoping that somebody on here who knows about the AiDot integration might respond.
