AIO Installer Fails - RP3
Been following these instructions - https://github.com/sjorsjes/home-assistant#install-mysql-db
Here’s the error - tried 2x’s - fails same spot each time -
Downloading/unpacking cryptography>=1.1 (from paramiko>=1.10,<3.0->fabric)
Downloading cryptography-1.6.tar.gz (410kB): 410kB downloaded
Running setup.py (path:/tmp/pip-build-B0dGwd/cryptography/setup.py) egg_info for package cryptography
no previously-included directories found matching 'docs/_build'
warning: no previously-included files matching '*' found under directory 'vectors'
Downloading/unpacking idna>=2.0 (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading idna-2.1-py2.py3-none-any.whl (54kB): 54kB downloaded
Requirement already satisfied (use --upgrade to upgrade): six>=1.4.1 in /usr/lib/python2.7/dist-packages (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading/unpacking setuptools>=11.3 (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading setuptools-30.4.0-py2.py3-none-any.whl (477kB): 477kB downloaded
Downloading/unpacking enum34 (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading enum34-1.1.6-py2-none-any.whl
Downloading/unpacking ipaddress (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading ipaddress-1.0.17-py2-none-any.whl
Downloading/unpacking cffi>=1.4.1 (from cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading cffi-1.9.1.tar.gz (407kB): 407kB downloaded
Running setup.py (path:/tmp/pip-build-B0dGwd/cffi/setup.py) egg_info for package cffi
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing libffi.pc’
No package ‘libffi’ found
Perhaps you should add the directory containing `libffi.pc’
Downloading/unpacking pycparser (from cffi>=1.4.1->cryptography>=1.1->paramiko>=1.10,<3.0->fabric)
Downloading pycparser-2.17.tar.gz (231kB): 231kB downloaded
Running setup.py (path:/tmp/pip-build-B0dGwd/pycparser/setup.py) egg_info for package pycparser
warning: no previously-included files matching 'yacctab.*' found under directory 'tests'
warning: no previously-included files matching 'lextab.*' found under directory 'tests'
warning: no previously-included files matching 'yacctab.*' found under directory 'examples'
warning: no previously-included files matching 'lextab.*' found under directory 'examples'
Installing collected packages: fabric, paramiko, cryptography, idna, setuptools, enum34, ipaddress, cffi, pycparser
Running setup.py install for cryptography
c/_cffi_backend.c:15:17: fatal error: ffi.h: No such file or directory
#include <ffi.h>
compilation terminated.
File “”, line 1, in
File “/tmp/pip-build-B0dGwd/cryptography/setup.py”, line 334, in
**keywords_with_side_effects(sys.argv)
File “/usr/lib/python2.7/distutils/core.py”, line 111, in setup
_setup_distribution = dist = klass(attrs)
File “/usr/lib/python2.7/dist-packages/setuptools/dist.py”, line 262, in init
self.fetch_build_eggs(attrs[‘setup_requires’])
File “/usr/lib/python2.7/dist-packages/setuptools/dist.py”, line 287, in fetch_build_eggs
replace_conflicting=True,
File “/usr/lib/python2.7/dist-packages/pkg_resources.py”, line 631, in resolve
dist = best[req.key] = env.best_match(req, ws, installer)
File “/usr/lib/python2.7/dist-packages/pkg_resources.py”, line 874, in best_match
return self.obtain(req, installer)
File “/usr/lib/python2.7/dist-packages/pkg_resources.py”, line 886, in obtain
return installer(requirement)
File “/usr/lib/python2.7/dist-packages/setuptools/dist.py”, line 338, in fetch_build_egg
return cmd.easy_install(req)
File “/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py”, line 636, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File “/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py”, line 666, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File “/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py”, line 856, in install_eggs
return self.build_and_install(setup_script, setup_base)
File “/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py”, line 1078, in build_and_install
self.run_setup(setup_script, setup_base, args)
File “/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py”, line 1066, in run_setup
raise DistutilsError(“Setup script exited with %s” % (v.args[0],))
distutils.errors.DistutilsError: Setup script exited with error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
Complete output from command /usr/bin/python -c “import setuptools, tokenize;file=’/tmp/pip-build-B0dGwd/cryptography/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-LhLrOV-record/install-record.txt --single-version-externally-managed --compile:
#include <ffi.h>
File “”, line 1, in
self.fetch_build_eggs(attrs['setup_requires'])
raise DistutilsError("Setup script exited with %s" % (v.args[0],))
Cleaning up…
Command /usr/bin/python -c “import setuptools, tokenize;file=’/tmp/pip-build-B0dGwd/cryptography/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-LhLrOV-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-B0dGwd/cryptography
Storing debug log for failure in /root/.pip/pip.log
Cloning into ‘fabric-home-assistant’…
remote: Counting objects: 223, done.
remote: Total 223 (delta 0), reused 0 (delta 0), pack-reused 223
Receiving objects: 100% (223/223), 104.12 KiB | 0 bytes/s, done.
Resolving deltas: 100% (125/125), done.
Checking connectivity… done.
File “/usr/local/lib/python2.7/dist-packages/fabric/network.py”, line 24, in
import paramiko as ssh
File “/usr/local/lib/python2.7/dist-packages/paramiko/init.py”, line 30, in
from paramiko.transport import SecurityOptions, Transport
File “/usr/local/lib/python2.7/dist-packages/paramiko/transport.py”, line 33, in
from cryptography.hazmat.backends import default_backend
ImportError: No module named cryptography.hazmat.backends
There was a problem importing our SSH library (see traceback above).
Please make sure all dependencies are installed and importable.
Don’t know where to go from there…
look here.
I experienced this problem a few times today. After looking at the errors and doing some Google searches I ran this command before trying the HA installer (after the “sudo apt-get update” and “sudo apt-get upgrade”):
sudo apt-get install libffi-dev
Running the HA installer still failed and based on those messages I also ran
sudo apt-get install libssl-dev
While I still received some warnings, the HA install progressed. It asked me for my password and continued. It is still progressing now.
I’ll update in the morning.
any luck with the new install?
Still no success. Windows machine that I was using for PuTTy rebooted during the night. Log file didn’t show an error at end. Rebooting RaspPI did not start HA.
This worked for me on a new RPI3 and fresh install - thanks!
@Charles_Brown - thanks - the link you sent me put me on track - the extra installs they had in there got me going.
Thanks!
