Aiohttp 2.0.5 not installable
While updating to home-assistant 0.42.3 from 0.41 I get errors installing the aiohttp package version 2.0.5.
Neither pip3 install --upgrade aiohttp==2.0.5 nor pip3 install aiohttp==2.0.5 is working.
This is the error I get:
Downloading/unpacking aiohttp==2.0.5
Downloading aiohttp-2.0.5.tar.gz (609kB): 609kB downloaded
Running setup.py (path:/tmp/pip-build-_7okt3o3/aiohttp/setup.py) egg_info for package aiohttp
    Error compiling Cython file:
    from .http_writer import HttpVersion, HttpVersion10, HttpVersion11, URL
    from .http_parser import RawRequestMessage, RawResponseMessage, DeflateBuffer
    from .streams import EMPTY_PAYLOAD, FlowControlStreamReader
    cimport cython
    from . cimport _cparser as cparser
    aiohttp/_http_parser.pyx:22:0: 'aiohttp.' is not a valid module name
      File "<string>", line 17, in <module>
      File "/tmp/pip-build-_7okt3o3/aiohttp/setup.py", line 27, in <module>
        extensions = cythonize(extensions)
      File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 840, in cythonize
        cythonize_one(*args[1:])
      File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 959, in cythonize_one
        raise CompileError(None, pyx_file)
    Cython.Compiler.Errors.CompileError: aiohttp/_http_parser.pyx
    missing cimport in module '.': aiohttp/_http_parser.pyx
    Compiling aiohttp/_websocket.pyx because it changed.
    Compiling aiohttp/_http_parser.pyx because it changed.
    Cythonizing aiohttp/_http_parser.pyx
    Complete output from command python setup.py egg_info:
cimport cython
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-_7okt3o3/aiohttp
Storing debug log for failure in /home/homeassistant/.pip/pip.log
@tedstriker
You followed these exact steps?
I followed these steps exactly. But it seems like I haven’t setup the virtual env properly in first place.
What I tried recently is to set include-system-site-packages = false in pyenv.cfg with success.
I went through the steps setting up the virtual environment again and now everything runs fine.
Thank you for pointing in the right direction.
