I get this error in the supervisor logs and a
500 Internal Server Error
Server got itself in trouble
whenever I attempt to load the ui for a plugin that uses ingress (node-red, terminal)
the node red flows I have are running and controlling the system.
Has anyone seen this issue or know how to remedy or what the root cause might be?
23-11-01 14:02:31 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/integrations/aiohttp.py", line 139, in sentry_app_handle
reraise(*_capture_exception(hub))
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/_compat.py", line 115, in reraise
raise value
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/integrations/aiohttp.py", line 129, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 185, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 201, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 220, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 280, in core_proxy
File "/usr/src/supervisor/supervisor/api/ingress.py", line 141, in handler
return await self._handle_request(request, addon, path, session_data)
File "/usr/src/supervisor/supervisor/api/ingress.py", line 217, in _handle_request
async with self.sys_websession.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1167, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 584, in _request
resp = await req.send(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 667, in send
await writer.write_headers(status_line, self.headers)
File "/usr/local/lib/python3.11/site-packages/aiohttp/http_writer.py", line 129, in write_headers
buf = _serialize_headers(status_line, headers)
File "aiohttp/_http_writer.pyx", line 132, in aiohttp._http_writer._serialize_headers
_safe_header(to_str(val))
File "aiohttp/_http_writer.pyx", line 116, in aiohttp._http_writer._safe_header
raise ValueError(
ValueError: Newline or carriage return character detected in HTTP status message or header. This is a potential security issue.
