Apparently the fix for the Apple TV problem in 0.40.1 is to upgrade aiohttp to 1.3.5
I did a sudo pip3 install --upgrade aiohttp
and
sudo pip3 install aiohttp ==1.3.5
and it does seem to upgrade however when I check the /deps folder it still shows 1.3.4
On another pi that I kind of keep in the wings as an emergency backup I ran the latest dev branch with which apple TV works and /deps shows aiohttp 1.3.5
How do I go about upgrading aiohttp to fix the Apple TV issue?
I did that and pip freeze says I have 1.3.5 but the apple TV thing isn’t fixed. But there is an aiohttp folder in /deps that is named aiohttp-1.3.4.dist-info.
On my other pi with dev branch where it works this reads 1.3.5 Pip freeze under a normal ssh login doesn’t even show aiohttp installed at all.
