Hi everyone
I’ve been troubleshooting diffrent issues over the weekend and I’ve finally gone back to a docker setup, after copying my old configuration files, home assistant worked fine, I just needed to remap device in my automation. However when I tried to reboot, home assistant would not start and I’m getting this error:
2023-11-12 11:39:54.765 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 82, in forwarded_middleware
from hass_nabucasa import ( # pylint: disable=import-outside-toplevel
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/__init__.py", line 27, in <module>
from .remote import RemoteUI
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/remote.py", line 21, in <module>
from .acme import AcmeClientError, AcmeHandler
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/acme.py", line 13, in <module>
from acme import challenges, client, crypto_util, errors, messages
File "/usr/local/lib/python3.11/site-packages/acme/client.py", line 29, in <module>
from acme import messages
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 936, in exec_module
File "<frozen importlib._bootstrap_external>", line 1069, in get_code
File "<frozen importlib._bootstrap_external>", line 729, in _compile_bytecode
EOFError: marshal data too short
Also if that help I’m on a rasberry pi 4 running pi OS
Thanks in advance
Samuel
