I am getting constant errors in my log file. Running v0.117.6.
The only thing I have changed recently is removed my ssl certs as it was causing an issue with my Plex integration.
2020-11-12 22:45:52 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 275, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
I am having several errors like yours, maybe some day could give us a light about how to solve itâŚ
2021-01-02 19:18:10 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 57, in _handle
return await self._handle_request(request, token, path)
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 121, in _handle_request
source_header = _init_header(request, token)
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 189, in _init_header
connected_ip = ip_address(request.transport.get_extra_info("peername")[0])
TypeError: 'NoneType' object is not subscriptable
I am on a Raspberry Pi 4B with 2020.12.2 HA version, the only thing that I have change recently I have remove deConz integration and deConz add-on, because I am using my conbee II with zigbee2mqtt not with deConz.
I had similar problem with HA. The same error log like RolandFran. Since yesterday was not possible connect with Android on Chrome or Samsung explorer. But on PC without problems. Today I connected to HA on Android with Firefox without problems. The problem is probably with HTTP protocol on Android -some changes in new distribution?
