Hi all,
Since some time I am experiencing severe issues with viewing my cams in Home Assistant. I am not exactly sure when it started. I guess since the update to 2021.3.4, but i might be wrong.
Below is my (pretty simple) straight forward cam configuration.
- name: Achtertuin
platform: generic
still_image_url: http://192.168.0.12/Streaming/channels/1/picture
stream_source: !secret HIKVISION_STREAMSOURCE_ACHTERTUIN
username: admin
password: <<left out>>
- name: Voordeur
platform: generic
still_image_url: http://192.168.0.13/Streaming/channels/1/picture
stream_source: !secret HIKVISION_STREAMSOURCE_VOORDEUR
username: admin
The first hour after a HASS reboot, everything is fine. Cam images are displayed in HASS (refreshed every second or so). This worked. fine for the past years. An hour after reboot, these errors start to appear in the log:
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 71, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 129, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 496, in get
return await self.handle(request, camera)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 531, in handle
return await camera.handle_async_mjpeg_stream(request)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 396, in handle_async_mjpeg_stream
return await self.handle_async_still_stream(request, self.frame_interval)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 386, in handle_async_still_stream
return await async_get_still_stream(
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 197, in async_get_still_stream
await write_to_mjpeg_stream(img_bytes)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 178, in write_to_mjpeg_stream
await response.write(
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_response.py", line 470, in write
await self._payload_writer.write(data)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_writer.py", line 107, in write
self._write(chunk)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_writer.py", line 67, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
These error messages continue to appear in my log for around 18 hours. Then they stop appearing, but instead i get these:
2021-03-30 11:48:59 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting camera image from Achtertuin
2021-03-30 11:49:09 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting camera image from Voordeur
2021-03-30 11:49:19 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting camera image from Achtertuin
2021-03-30 11:49:29 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting camera image from Voordeur
Obviously there is nothing wrong with the cameras itself, even though i tried restarting them.
There is not much online i can find about this. I am at the point of re-installing everything.
Maybe someone here has a good suggestion?
