Hello everyone!!!
I have been running my installation for a while now but am getting strange errors in my logs.
I am using DUCK dns for an SSL connection. NGINX Home Assistant SSL proxy I use to get an https connection from outside.
I do port forwarding via port 443 external to port 443 internal to my ip address running home assistant.
These are my http parameters.
http:
ip_ban_enabled: true
login_attempts_threshold: 3
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
My internal and external url are set under settings – system – network
internal http://192.168.1.X:8123
external https:///xxx.duckdns.org
Everything works perfectly both internal and external. The only thing I see are many of the following errors when I connect back through my internal url.
Logger: aiohttp.server
Source: /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py:403
First occurred: 09:22:52 (44 occurrences)
Last logged: 09:22:57
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 332, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Invalid method encountered'"
What could this be? Please help me out.
Thank you!!!
