I get a single aiohttp.server exception when Home assistant restarts
It has been going on for a bit (unsure how long), the setup currently is:
Home Assistant 2023.1.4
Supervisor 2022.12.1
Operating System 9.4
Frontend 20230110.0 - latest
I have run it having removed all HACS integrations and the same exception occurs - is there any way of finding out more info on this exception - there is no other stack info in the log as it is at the moment that would help narrow it down… (any other logging changes I should make then repost?)
## Show full logs
2023-01-13 10:36:45.145 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.149 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.152 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.154 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.157 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mobilealerts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.160 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:45.163 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-13 10:36:54.116 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1191, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 514, in start
resp, reset = await task
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 460, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 613, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 286, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 99, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1170, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1200, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 268, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 343, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
