AION EMS Zeus v14.8.10.1
Hotfix release for v14.8.10.
Fixed
- Fixed the Statistics page failing to load with:
heatPumpDevice is not defined - Corrected Heat Pump Statistics to use the registered Heat Pump device available within the Statistics context.
- Preserves the v14.8.10 Heat Pump live Electrical Input and Thermal Output fixes.
- Preserves the Live COP idle/stopped fallback to
0.00. - Preserves the completed Switch Hub staged solar control.
- Preserves the Command Center Switch Hub Active Devices display.
- Preserves the ELWA 800 W minimum SOLAR start threshold.
Installation
Release asset:
aion_ems_zeus.zip
Restart Home Assistant after updating.
A browser hard refresh may be required to load the updated Zeus frontend.
