Home Assistant newbie here. I recently purchased a wifi IR controller (Frankever brand) that I set up using Tuya to control my Mitsubishi mini-split heat pump. I got it working with the Tuya app, but I’d like to get it working with Home Assistant also. Can anyone point me in the right direction to setting up my yaml config file to see the AC and be able to control it? The HA help on Tuya component wasn’t particular helpful with examples.
Setting it up like this should work:
What do you see in your log after setting this up?
Do you have other tuya devices to check with?
Hi yds. Did you manage to get it to work? I am trying to do the same thing. Using the Tuya integration doesn’t show any device.
Hi. I have the same issue… In Smart Life i have 3 configured AC devices (all created after setup IR devices), but i cant see it in HA… =(
PS Integration works fine, ie i can see and use scenes from Smart Life in HA.
