Air purifier fan speeds
I have a Breville Easy Air Purifer connected via Tuya.
Works totally fine with HA and Tuya integration. However the fan speed settings do not appear. I can change the fan speed in the Tuya app, but those entities don’t seem to appear in HA.
All the other settings appear. Just not the fan speeds.
Thanks!
I have been able to add my Breville Air Purifier through tuya-local
Tuya-local is different to local-Tuya. It’s easy to install with HACS.
copy the settings at the bottom of this post into a file called “the_Breville_Easy_Air_purifier.yaml”
then save in the “custom_components\tuya_local\devices” folder.
Then when you add a device in the normal way for Tuya-Local it should give you the option of “the Breville Easy Air™”
It has all of the same settings as the Tuya App. Except I didn’t bother with filter reset.
name: the Breville Easy Air™
products:
  • id: k2mlahbu9v4xxdlb
    primary_entity:
    entity: switch
    dps:
    • id: 1
      type: boolean
      mapping:
      • dps_val: true
        icon: “mdi:air-purifier”
      • dps_val: false
        icon: “mdi:air-purifier-off”
        secondary_entities:
  • entity: switch
    category: config
    icon: “mdi:lightbulb-night”
    dps:
    • id: 8
      type: boolean
  • entity: switch
    category: config
    icon: “mdi:shield-bug”
    dps:
    • id: 9
      type: boolean
  • entity: sensor
    name: Filter Days Left
    category: diagnostic
    icon: “mdi:air-filter”
    dps:
    • id: 16
      type: integer
      unit: day
  • entity: select
    category: config
    dps:
    • id: 19
      type: string
      mapping:
      • dps_val: “cancle”
        value: “Cancel”
        icon: “mdi:timer”
      • dps_val: “2”
        value: “2 hour”
        icon: “mdi:fan-clock”
      • dps_val: “4”
        value: “4 hours”
      • dps_val: “8”
        value: “8 hours”
  • entity: select
    category: config
    dps:
    • id: 4
      type: string
      mapping:
      • dps_val: “low”
        value: “1 - Low”
        icon: “mdi:fan-speed-1”
      • dps_val: “mid”
        value: “2 - Mid”
        icon: “mdi:fan-speed-2”
      • dps_val: “high”
        value: “3 - High”
        icon: “mdi:fan-speed-3”
      • dps_val: “turbo”
        value: “4 - Turbo”
        icon: “mdi:fan-plus”
  • entity: sensor
    icon: “mdi:timer”
    dps:
    • id: 20
      type: integer
      unit: min
I’ve been trying to use your method to add the extra controls that are missing by default, but haven’t had much luck.
If I add a new file, it doesn’t appear as an option when I try add my device.
I tried amending the existing file that comes up by default when I try to add the device. Thinking that I could just add in the missing control. But still no luck. If I try add Night Mode for example, the file won’t appear as an option.
Any tips?
Similar problem here. I have a Jafanda Air Purifier (aka, “fan”, to save typing).
It comes with it’s own app, but on a hunch, I installed Tuya Smart, added the fan and tada, exactly the same appearance. The Jafanda app is just a stripped down rebranded Tuya app.
I installed local Tuya and added the fan using information obtained from the Tuya IoT developer platform (local_key). I then did a Properties Query and got a lot of the DPs.
With this info, I’m able to add many of the entities. Some escape me though. For example, in the app, there is a “Mode” option; Manual, Auto and Sleep. And in the properties printout, I see
        "code": "mode",
        "custom_name": "",
        "dp_id": 3,
        "time": 1740026705944,
        "type": "enum",
        "value": "manual"
But I’m not sure how to get this into a drop down list.
Also, there’s a (soft) power button on the unit and a property
        "code": "switch",
        "custom_name": "",
        "dp_id": 1,
        "time": 1740022625466,
        "type": "bool",
        "value": true
but the HACS “Edit a Device” page does not allow me to input a DP of 1.
Any help most appreciated! Pseudo code a pointer to some docs or …
Hiya all,
same issue here.
I can add my air purifier of a switch entity to turn it on & off, but cannot control the fan no matter what I tried.
any insight on this, that’d be much appreciated.
