Air quality alert notification (Airobot)
Description
Get notified on your phone when the air quality in your home drops below acceptable levels. Works with any Airobot smart thermostat equipped with the optional CO₂ sensor.
What it does
  1. Monitors the air quality (CO₂) sensor on your Airobot thermostat
  2. Detects when the CO₂ level rises above a configurable threshold (default: 1000 ppm)
  3. Sends a mobile notification with the current reading and threshold value
  4. Only alerts when the value is actively rising, so you won’t get duplicate notifications from small fluctuations
Inputs
Input Description Default
Air quality sensor The sensor entity that measures air quality (CO₂) Required
Threshold Alert when value goes above this number (0–2000) 1000
Mobile device Device to send notification to (Mobile App) Required
Notification title Title for the notification “Poor Air Quality”
Notification message Message body (use {{ trigger.to_state.state }} for current value and {{ trigger.above }} for threshold) “Air quality in {area} is {value} (threshold: {threshold})”
Requirements
  • Airobot integration configured with a thermostat that has the optional CO₂ sensor
  • Mobile App set up on at least one device
Blueprint import
blueprint:
  name: "Airobot Air Quality Alert"
  description: >-
    Sends a notification when air quality exceeds a configurable
    threshold. Works with any Airobot thermostat that has the
  domain: automation
  input:
    air_quality_sensor:
      name: "Air quality sensor"
      selector:
        entity:
          filter:
            - domain: sensor
    threshold:
      description: "Alert when value goes above this number"
      default: 1000
      selector:
        number:
          min: 0
          max: 2000
    notify_device:
      description: "Device to send notification to"
      selector:
        device:
          filter:
            - integration: mobile_app
    notification_title:
      description: "Title of the notification"
      default: "Poor Air Quality"
      selector:
        text:
    notification_message:
      description: >-
      default: >-
        Air quality in {{ area_name(trigger.entity_id) }}
        is {{ trigger.to_state.state }}
        (threshold: {{ trigger.above | int }})
      selector:
        text:
          multiline: true
triggers:
  - trigger: numeric_state
    entity_id: !input air_quality_sensor
    above: !input threshold
conditions: >-
    trigger.from_state.state | float(0)
    < trigger.to_state.state | float(0)
actions:
  - device_id: !input notify_device
    domain: mobile_app
    type: notify
    title: !input notification_title
    message: !input notification_message
