Has anyone this lock? Experience?
Also interestedā¦
also interested
Also interestedā¦Is any update?
Hello someone have any news about "Airbnk M530 TUYA Smart Lock " HA integration?
Hi, Iām also interesting in such solution. Is there any update.
Hello, have someone any news about "Airbnk M531 TUYA Smart Lock " HA integration?
I bought the version with Zigbee, and with the help of Tuya - Smart Life works ⦠but I prefer to work in Homeassistant. I use ZHA and it recognizes it - or finds it, but only finds 2 entity is unavailable under Diagnostic like:
- sensor.tyst12_xxxxxx_xxxxxx_xxxxxxx_basic_rssi
- sensor.tyst12_xxxxx_xxxxx_xxxxxx_basic_lqi
some ideas or solutions?
Also looking for an integration.
Iāve found this, but looking for a solution without ESP32.
Perhaps someone can port it.
Hey, Iāve got a different Tuya lock so I could maybe help you out.
So you got the ZigBee version ?
In the Tuya app, can you press a button to lock and unlock ?
Can you add a scene in Tuya to lock ?
Can you add a scene in Tuya to unlock ?
If yes then integration is very easy
Hi Ak-d0V,
thanks for your reply.
So, I have a zigbee version that works in āSmart Lifeā
Setings:
Automation - scene:
ok, iām very excited about what / how can you help me
Can you unlock in a smart scene ?
If you create a new scene, is there an option to unlock or is it just for lock ? (3rd picture)
I tested, but failed. No, i canāt unlock, over smart scene, or Automation. I guess, tuya/smart life, doesnāt support this feature.
What i need? ZHA or zigbe2mqtt? To integrate in HA?
what you suggested to me, I intended to do for the test, but to this day I have not come to this.
Sorry it doesnāt work.
ok, we have some other suggestion?
ps:
since I am currently using ZHA, I am ready to replace the integration with zigbee2mqtt.
insofar as this integration would work.
Hello, someone have any news about We-Here / Airbnk M531 / M530 / M500?
It contains Zigbee and bluetooth in the device itselfā¦
Hi, since itās zigbee tuya lock
Have you tried pairing it with zemismart homekit hub and use the homekit integration to control it?
Btw, you can still remotely lock/unlock from the tuya/smartlife right?
I havenāt tried this yet. Unlocking works remotely via the Smart live app.
I will order, test and then report back.
Hello
Any news about this integration?
hi, are there any new about this problem?
Buyed this lock. Tuya app can only Unlock it, and not reporting anything else.
Tried to integrate it to z2m, discovered datapoints but no luck forward.
Check the post from elektrinis from May 2022
MQTT control of Airbnk locks. Contribute to rospogrigio/airbnk_mqtt
I managed to implement this thing.![]()
And it works.
