Is this the correct way to switch on (or even change the temperature) aircon’s ?
alias: 'Switch : Airco living 20 graden'
sequence:
- device_id: a14f058bae5fb4159978ec5c9cb58364
domain: climate
entity_id: climate.airco_living_links
type: set_hvac_mode
hvac_mode: heat
- device_id: 0a5190bad4520620184413382194401a
domain: climate
entity_id: climate.airco_living_rechts
type: set_hvac_mode
hvac_mode: heat
- service: climate.set_temperature
device_id:
- a14f058bae5fb4159978ec5c9cb58364
- 0a5190bad4520620184413382194401a
temperature: 20
mode: single
It works mostly wel, but sometimes there is only one aircon switched on.
Aircon’s (Samsung) were connected to Smartthings with a MIM-H04 module. When I do the automatisation with the Smartthings app, it allways works…
