I use a wifi module for my airconditioning in my living room. From airconwithme.com
There are some smart people who has written a script to control the aircon.
Can somebody help me to create a component or to get it working in a climate component?
> #!/usr/bin/env bash
> #Airconwithme script (airconwithme.com)
> #Written by KingOfDois. BSD 3-clause license.
> USAGE="usage: ${0} ip set|get option [value]"
> #pseudo: login credentials.
> #security note: wget leaks user/password in process list
> if [ -z "${AIRCO_PASSWORD}" ]; then
> AIRCO_PASSWORD=operator
> fi
> if [ -z "${AIRCO_USER}" ]; then
> AIRCO_USER=operator
> fi
> #pseudo: 1st argument is IP
> if [ -z "${1}" ]; then
> echo ${USAGE}
> exit 1
> else
> AIRCO_IP="${1}"
> fi
> #pseudo: 2nd argument is set|get
> if [ "${2}" != "set" ] && [ "${2}" != "get" ]; then
> echo ${USAGE}
> exit 1
> fi
> DIRECTION=${2}
> #pseudo: more variables
> ACTION=${3}
> DO=${4}
> VALUE=0
> EXIT=0
> #pseudo: functions
> function stderr () {
> cat - 1>&2
> #pseudo: action table
> ACTIONS=(power mode speed vane setpoint return alarm)
> UIDS=(1 2 4 5 9 10 14)
> #pseudo: select uid from action
> FOUND=0
> for i in "${!ACTIONS[@]}"
> do
> if [ "${ACTIONS[${i}]}" == "${ACTION}" ]; then
> FOUND=1
> WORK_UID=${UIDS[${i}]}
> fi
> done
> if [ ${FOUND} -eq 0 ]; then
> echo "available actions: ${ACTIONS[@]}"
> exit 1
> fi
> #pseudo: work the $ACTION / $VALUE with $uid available
> if [[ "${DIRECTION}" == "set" ]]; then
> if [[ "${ACTION}" == "power" ]]; then OPTIONS=(on off); VALUES=(1 0); fi
> if [[ "${ACTION}" == "mode" ]]; then OPTIONS=(auto heat dry fan cool); VALUES=(0 1 2 3 4); fi
> if [[ "${ACTION}" == "speed" ]]; then OPTIONS=(1 2 3 4); VALUES=(1 2 3 4); fi
> if [[ "${ACTION}" == "vane" ]]; then OPTIONS=(1 2 3 4 swing); VALUES=(1 2 3 4 10); fi
> if [[ "${ACTION}" == "setpoint" ]]; then
> if [ "${DO}" == "" ]; then
> echo "value: 180 till 300 (18.0 till 30.0 degree C)"
> exit 1
> else
> VALUE=$DO;
> fi
> fi
> fi
> #pseudo: now select the proper value based on the action
> if [ "${OPTIONS}" != "" ]; then
> FOUND=0
> for i in "${!OPTIONS[@]}"
> do
> if [ "${OPTIONS[${i}]}" == "${DO}" ]; then
> FOUND=1
> VALUE=${VALUES[${i}]}
> fi
> done
> echo "available [${ACTION}] options: ${OPTIONS[@]}"
> exit 1
> fi
> fi
> COOKIE=$(mktemp)
> #pseudo: login
> LOGIN_RESPONSE=$(mktemp)
> LOGIN_ERROR=$(mktemp)
> wget --save-cookies=${COOKIE} \
> --keep-session-cookies \
> --post-data="{\"command\":\"login\",\"data\":{\"username\":\"${AIRCO_USER}\",\"password\":\"${AIRCO_PASSWORD}\"}}" \
> --output-document=${LOGIN_RESPONSE} \
> --header="Content-Type: application/json" \
> --header="Accept: application/json" \
> --tries=3 \
> --timeout=30 \
> http://${AIRCO_IP}/api.cgi 2> ${LOGIN_ERROR}
> LOGIN_RC=$?
> if [ "${LOGIN_RC}" -ne 0 ]; then
> cat ${LOGIN_ERROR}|stderr
> EXIT=1
> fi
> if [ "$(grep -c '"success":true' ${LOGIN_RESPONSE})" -ne 1 ]; then
> echo "something went wrong while logging in"|stderr
> echo "response: $(cat ${LOGIN_RESPONSE})"|stderr
> EXIT=1
> fi
> #pseudo: get sessionID from login
> SESSION_ID=$(awk -F '"sessionID":"' '{print $2}' ${LOGIN_RESPONSE}|awk -F '"' '{print $1}')
> if [ "${SESSION_ID}" != "" ]; then
> ACTION_RESPONSE=$(mktemp)
> ACTION_ERROR=$(mktemp)
> if [ "${DIRECTION}" == "set" ]; then
> POST_DATA="{\"command\":\"setdatapointvalue\",\"data\":{\"sessionID\":\"${SESSION_ID}\",\"uid\":${WORK_UID},\"value\":${VALUE}}}"
> else
> POST_DATA="{\"command\":\"getdatapointvalue\",\"data\":{\"sessionID\":\"${SESSION_ID}\",\"uid\":${WORK_UID}}}"
> fi
> wget --load-cookies=${COOKIE} \
> --post-data="${POST_DATA}" \
> --output-document=${ACTION_RESPONSE} \
> --tries=3 \
> --timeout=30 \
> http://${AIRCO_IP}/api.cgi 2> ${ACTION_ERROR}
> ACTION_RC=$?
> if [ "${ACTION_RC}" -ne 0 ]; then
> cat ${ACTION_ERROR}|stderr
> EXIT=1
> fi
> if [ "$(grep -c '"success":true' ${ACTION_RESPONSE})" -eq 1 ]; then
> echo "saved";
> else
> RESPONSE_VALUE=$(awk -F ',"value":' '{print $2}' ${ACTION_RESPONSE}|awk -F ',"status"' '{print $1}')
> #sed 's/\"//g'
> echo "${RESPONSE_VALUE}"
> fi
> else
> echo "${DIRECTION} failed"|stderr
> echo "response: $(cat ${ACTION_RESPONSE})"|stderr
> EXIT=1
> fi
> #end if SESSION_ID
> fi
> #cleanup
> if [ -f "${COOKIE}" ]; then rm ${COOKIE}; fi
> if [ -f "${LOGIN_RESPONSE}" ]; then rm ${LOGIN_RESPONSE}; fi
> if [ -f "${LOGIN_ERROR}" ]; then rm ${LOGIN_ERROR}; fi
> if [ -f "${ACTION_RESPONSE}" ]; then rm ${ACTION_RESPONSE}; fi
> if [ -f "${ACTION_ERROR}" ]; then rm ${ACTION_ERROR}; fi
> exit ${EXIT}
Or in Powershell:
$ipAddress = "192.168.3.217"
#Login
$response = Invoke-Restmethod -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:null}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept-Language"="en-US,en;q=0.9,nl;q=0.8"; "User-Agent"="Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"login`",`"data`":{`"username`":`"admin`",`"password`":`"admin`"}}";
$sessionId = $response.data.id.sessionID
# Set mode to Heat
Invoke-Restmethod -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:%22$sessionId%22}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"setdatapointvalue`",`"data`":{`"sessionID`":`"$sessionId`",`"uid`":2,`"value`":1}}"
# Set fan speed to speed 3
Invoke-WebRequest -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:%22$sessionId%22}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"setdatapointvalue`",`"data`":{`"sessionID`":`"$sessionId`",`"uid`":4,`"value`":3}}"
# Set temperature to 23C
Invoke-WebRequest -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:%22$sessionId%22}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"setdatapointvalue`",`"data`":{`"sessionID`":`"$sessionId`",`"uid`":9,`"value`":230}}"
# Set position to Swing
Invoke-WebRequest -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:%22$sessionId%22}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"setdatapointvalue`",`"data`":{`"sessionID`":`"$sessionId`",`"uid`":5,`"value`":10}}"
# Turn on A/C
Invoke-WebRequest -Uri "http://$ipAddress/api.cgi" -Method "POST" -Headers @{"Cookie"="Intesis-Webserver={%22sessionID%22:%22$sessionId%22}"; "Origin"="http://$ipAddress"; "Accept-Encoding"="gzip, deflate"; "Accept"="application/json, text/javascript, */*; q=0.01"; "Referer"="http://$ipAddress/"; "X-Requested-With"="XMLHttpRequest"; "DNT"="1"} -ContentType "application/json; charset=UTF-8" -Body "{`"command`":`"setdatapointvalue`",`"data`":{`"sessionID`":`"$sessionId`",`"uid`":1,`"value`":1}}"
