Hi, this is my known list (I do have an actual DFEVOCTRL08, should I create a fake remote besides the real one?)
"18:100900":
class: HGI
"32:162627":
class: FAN
_note: SIBER DF EVO4
"37:143839":
class: REM
_note: SIBER DF EVO4 Multicontrol DFEVOCTRL08
commands:
away: " I --- 37:143839 32:162627--:------ 22F1 003 000107"
low: " I --- 37:143839 32:162627--:------ 22F1 003 000207"
medium: " I --- 37:143839 32:162627--:------ 22F1 003 000307"
high: " I --- 37:143839 32:162627--:------ 22F1 003 000407"
boost: " I --- 37:143839 32:162627--:------ 22F1 003 000707"
bypass_off: " W --- 37:143839 32:162627--:------ 22F7 003 00C8EF"
bypass_on: " W --- 37:143839 32:162627--:------ 22F7 003 0000EF"
bypass_auto: " W --- 37:143839 32:162627--:------ 22F7 003 00FFEF"
calendar_off: " W --- 37:143839 32:162627--:------ 22B0 002 0006"
calendar_on: " W --- 37:143839 32:162627--:------ 22B0 002 0005"
And this is the error in the log when I try to send any command:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 16:22:21 (4 occurrences)
Last logged: 16:29:22
[140114538429696] Unexpected exception
[140114154573104] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 996, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1068, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 758, in async_handle_set_fan_mode_service
await self.async_set_fan_mode(fan_mode)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 766, in async_set_fan_mode
await self.hass.async_add_executor_job(self.set_fan_mode, fan_mode)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 762, in set_fan_mode
raise NotImplementedError
NotImplementedError`
I tried to send the command via teh FAN entity and via actions (services), with the same result. I managed to call the learn a command service sucessfully, but when trying to send the command I always get the same error:
Failed to perform the action climate/set_hvac_mode. unknown error
or
Failed to perform the action ramses_cc.send_command. Unknown error
if sent directly from actions.
Note: Gateway has been replaced as the first one could not connect to Putty in order to setup wifi and mqtt. I’m running this directly on HA usb to avoid any MQTT background issue.
