Hi
I am trying to write new custom component for airly. My previous attempt was in November, and it worked. Now after update to 0.60.0 it stopped working. Also error I get is not very helpful… It looks like I am not passing all required parameters, even though everything is there…
Error:
2018-01-01 22:10:56 ERROR (MainThread) [homeassistant.config] Invalid config for [airly]: required key not provided @ data['platform']. Got None. (See /home/ha/.homeassistant/configuration.yaml, line 328). Please check the docs at https://home-assistant.io/components/airly/
2018-01-01 22:10:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component airly
File "/home/ha/python_libs/lib/python3.5/site-packages/homeassistant/setup.py", line 193, in _async_setup_component
component.setup, hass, processed_config)
AttributeError: module 'custom_components.airly' has no attribute 'setup'
2018-01-01 22:11:15 ERROR (MainThread) [aiohttp.access] Error in logging
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/helpers.py", line 554, in __get__
return inst._cache[self.name]
KeyError: 'remote'
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/helpers.py", line 521, in log
for key, value in fmt_info:
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/helpers.py", line 513, in <genexpr>
for key, method in self._methods)
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/helpers.py", line 473, in _format_a
ip = request.remote
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/helpers.py", line 556, in __get__
val = self.wrapped(inst)
File "/home/ha/python_libs/lib/python3.5/site-packages/aiohttp/web_request.py", line 319, in remote
peername = transport.get_extra_info('peername')
File "/usr/lib/python3.5/asyncio/sslproto.py", line 306, in get_extra_info
return self._ssl_protocol._get_extra_info(name, default)
File "/usr/lib/python3.5/asyncio/sslproto.py", line 546, in _get_extra_info
return self._transport.get_extra_info(name, default)
AttributeError: 'NoneType' object has no attribute 'get_extra_info'
Configuration:
airly:
api_key: SECRET
latitude: SECRET
longitude: SECRET
resources:
- pm10
And the code for the custom component:
#import urllib2
#from urllib.request
from urllib.request import Request, urlopen
import json
import string
import logging
import voluptuous as vol
import requests
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.helpers.entity import Entity
from homeassistant.const import ( CONF_API_KEY, CONF_LATITUDE, CONF_LONGITUDE, CONF_RESOURCES, STATE_OFF, STATE_ON, CONF_TYPE)
import homeassistant.helpers.config_validation as cv
#from homeassistant.helpers.event import track_time_change
#DOMAIN = 'airly_airquality'
#DEPENDENCIES = []
#REQUIREMENTS = []
_LOGGER = logging.getLogger(__name__)
#CONF_ARG = 'arg'
SENSOR_TYPES = {
'airQualityIndex': ['airQualityIndex'],
'pm10': ['pn10'],
'pm25': ['pm25'],
'pollutionLevel': ['pollutionLevel'],
# Validation of the user's configuration
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_API_KEY): cv.string,
vol.Required(CONF_LONGITUDE): cv.string,
vol.Required(CONF_LATITUDE): cv.string,
vol.Optional(CONF_RESOURCES, default=['pm10']):
vol.All(cv.ensure_list, [vol.In(SENSOR_TYPES)])
#vol.All(cv.ensure_list, [vol.Schema({ vol.Required(CONF_TYPE): vol.In(SENSOR_TYPES),})])
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Setup the sensor platform."""
dev = []
_LOGGER.error(CONF_RESOURCES)
for resource in config[CONF_RESOURCES]:
dev.append(AirlySensor(
resource[CONF_TYPE], resource[CONF_ARG]))
add_devices(dev, True)
apikey = config.get(CONF_API_KEY)
latitude = config.get(CONF_LATITUDE)
longtitude = config.get(CONF_LONGITUDE)
class AirlySensor(Entity):
"""Representation of a Sensor."""
def __init__(self, sensor_type, argument=''):
"""Initialize the sensor."""
self._name = '{} {}'.format(SENSOR_TYPES[sensor_type][0], argument)
self.argument = argument
self.type = sensor_type
self._state = None
#"""Run once per hour."""
#track_time_change(hass, self.update, minute=0)
@property
def name(self):
"""Return the name of the sensor."""
return "Airly " + self._name.rstrip()
@property
def state(self):
"""Return the state of the sensor."""
return self._state
def update(self):
"""Fetch new state data for the sensor."""
url = "https://airapi.airly.eu/v1/mapPoint/measurements?latitude=SECRET&longitude=SECRET"
req = Request(url)
req.add_header('apikey', apikey)
a = urlopen(req)
data = a.read()
encoding = a.info().get_content_charset('utf-8')
jsondata = json.loads(data.decode(encoding))
measurements = jsondata["currentMeasurements"]
if self.type == 'airQualityIndex':
self._state = measurements["airQualityIndex"]
if self.type == 'pm10':
self._state = measurements["pm10"]
if self.type == 'pm25':
self._state = measurements["pm25"]
if self.type == 'pollutionLevel':
self._pollutionLevel = measurements["pollutionLevel"]
