AirPlay 2 Multiroom Audio
Turn your existing PulseAudio-backed audio hardware and your Google Cast (Chromecast/Google Home) speakers into AirPlay 2 receivers, so you can play to all of them — individually or grouped — from any AirPlay 2 source (iPhone, iPad, Mac).
This addon merges what used to be two separate things — AirPlay 2 receivers for local sound cards, and a bridge that relays AirPlay 2 audio to Google Cast devices — into a single Home Assistant addon.
What it does
  • Scans your system’s PulseAudio sinks and creates an AirPlay 2 receiver (via shairport-sync) for each one, so each physical output (a zone, a room, a card’s channel pair) shows up as its own AirPlay 2 speaker.
  • Scans your network for Google Cast devices (speakers, speaker groups/stereo pairs, Cast-enabled soundbars) and creates a matching AirPlay 2 receiver for each one too, relaying the audio through to Cast — so devices that don’t natively speak AirPlay 2 still show up as AirPlay 2 speakers.
  • Skips any Cast device that’s already advertising its own, real AirPlay 2 receiver (some TVs and soundbars have this built in) — it’s detected automatically, not configured by name, so you never end up with two entries for the same physical device.
  • All AirPlay 2 zones — sink-backed and Cast-backed alike — support AirPlay 2’s native multi-room grouping, so you can select several speakers at once from your source device.
  • This addon doesn’t limit you to just the zones it creates: any other AirPlay 2 receiver already on your network (a HomePod, a smart TV, a soundbar with AirPlay 2 built in, another addon’s receivers) shows up in your source’s AirPlay picker right alongside this addon’s zones, and can be grouped together with them the same way, since AirPlay 2 multi-room isn’t specific to this addon — it’s a standard feature of the protocol itself.
Requirements
  • A Home Assistant host with PulseAudio already set up and your sound hardware’s sinks configured (see Setting up a new zone below).
  • host_network: true — this addon needs real access to your LAN for AirPlay 2 (mDNS/Bonjour) and Cast device discovery to work.
  • Google Cast devices must be on the same network/VLAN as the Home Assistant host; discovery relies on mDNS, which typically doesn’t cross VLANs without an mDNS reflector.
Sink-backed zones (local sound cards, USB DACs, HDMI, Bluetooth speakers, etc.): this addon only creates an AirPlay 2 zone for a PulseAudio sink that’s a module-remap-sink — and it names the zone after that remap sink’s own name, so the remap sink’s name is what shows up in your AirPlay picker. A raw hardware sink on its own (even a plain stereo card with nothing multi-channel about it) won’t be picked up until it has a remap sink built on top of it — this applies even when the remap sink would just be a 1:1, all-channels passthrough of the card. A Bluetooth speaker works the same way once it’s paired and PulseAudio shows it as a sink; see Using a Bluetooth speaker as a zone under Advanced.
The recommended way to create these remap sinks is with the Multi-room Audio Controller addon, rather than creating them by hand with pactl. Add or rename a zone there, restart this addon afterward, and it’ll pick up the new remap sink and create (or rename) the matching AirPlay 2 zone for it automatically.
Cast-backed zones (Google/Nest speakers, Cast groups, Cast-enabled soundbars): nothing to configure — every Cast device found on the network gets its own AirPlay 2 zone automatically, unless it’s already got a native AirPlay 2 receiver of its own (see above).
Restarting
Restart this addon whenever you:
  • Add, rename, or remove a PulseAudio remap sink.
  • Add or remove a Google Cast device on your network.
A restart re-scans both PulseAudio and the network and regenerates the AirPlay 2 zone list to match. Zone names and their AirPlay 2 ports are persisted across restarts, so a zone’s identity in your AirPlay picker stays stable — it won’t reappear as a “new” device each time.
If your AV receiver or a TV was power-cycled or had its HDMI cable unplugged, restarting this addon (or just waiting for its next scheduled restart) will also recover sinks that PulseAudio otherwise leaves silently stuck.
Troubleshooting
Logs live under /config/shairport-sync/logs/:
  • generate_airplay2_services.log — what happened on the most recent sink scan/zone generation pass (which sinks were found, which ports were assigned, any sinks that had to be bounced/recreated).
  • <zone name>-ap2.log — each zone’s own shairport-sync (AirPlay 2 receiver) log.
  • cast_bridge_manager.log — Cast device discovery and the overall status of each Cast Bridge zone’s shairport-sync/relay process pair.
  • <zone name>-bridge.log (under /config/cast-bridge/logs/) — a Cast-backed zone’s own relay log (its connection to the Cast device, playback start/stop).
A zone doesn’t show up in your AirPlay picker:
  • Sink-backed: confirm it’s a module-remap-sink sink (pactl list sinks short) and check generate_airplay2_services.log for its name.
  • Cast-backed: check cast_bridge_manager.log for whether it was found on the last scan, and whether it was excluded as already having its own AirPlay 2 receiver.
No sound from a specific zone, but it shows up fine: check that zone’s own log (-ap2.log for sink zones, -bridge.log for Cast zones) for connection errors, then restart the addon.
A zone plays briefly then goes silent, or never recovers after a receiver/TV is power-cycled: restart the addon — this forces PulseAudio to reopen the underlying hardware device.
Known limitations
  • The iOS Spotify app’s own in-app device picker initially shows these zones as classic AirPlay-1-only, regardless of what they actually support. If you hit this, use iOS’s system AirPlay picker instead (tap the AirPlay icon, or the status-bar clock/Dynamic Island while something is playing) to select the zone as full AirPlay 2 at least once — after that first play, Spotify’s own picker seems to pick up on its real AirPlay 2 capability and shows it correctly from then on.
  • A brand-new Cast device or a renamed/removed one is only picked up on the next addon restart — there’s no live rescanning while it’s running.
  • Grouping a Cast-backed zone together with a sink-backed (true AirPlay 2) zone likely won’t play in tight sync. Sink-backed zones stay tightly synced with each other because they share AirPlay 2’s own timing protocol (PTP, via nqptp) directly. A Cast-backed zone’s audio, by contrast, is relayed through to the Cast device rather than played by an AirPlay 2 receiver itself, so it picks up its own separate buffering/latency along the way — it should stay in sync with other Cast-backed zones reasonably well, but not with the sink-backed ones. If you’re grouping across both kinds regularly, placing AP2 (sink-backed) speakers and Cast-backed speakers in different, separated areas of the house helps mask any drift between them.
Advanced
Custom general configuration per zone
Each sink-backed zone’s shairport-sync configuration is regenerated on every start, so edits made directly to <zone name>-ap2.conf are overwritten. To keep per-zone settings across restarts and updates, use the zone’s custom file instead. It’s what makes per-device tweaks possible, such as the latency offset a Bluetooth speaker or a Cast device needs to stay in sync with your other rooms (for Bluetooth, see Using a Bluetooth speaker as a zone below):
/config/shairport-sync/config/<zone name>-ap2.custom
(On Home Assistant this folder is the addon’s config share, addon_configs/<addon slug>/shairport-sync/config/.)
  • The file is created automatically on the first start after the zone exists, containing only comments, so it does nothing until you add settings to it. It is never overwritten once it exists, and one file is created per zone.
  • It is spliced into that zone’s general block with libconfig’s @include, so put only bare general settings in it, each ending with a semicolon. Don’t add a general = { ... } wrapper, and don’t use it for other groups such as sessioncontrol or pulseaudio.
  • Don’t set anything the addon already writes into general: name, port, interface, output_backend, udp_port_base, or mdns_backend. A key defined twice stops that zone’s shairport-sync from starting.
  • A syntax error in the file also stops that one zone from starting. The error appears in <zone name>-ap2.log.
  • Restart the addon after editing the file.
Example: compensating for a Bluetooth speaker or a Cast device. Both add delay of their own that AirPlay 2 doesn’t know about, so they play late when grouped with your other rooms. To make one zone play 250 ms early, put this in that zone’s .custom file and restart:
audio_backend_latency_offset_in_seconds = -0.25;
The value is in seconds, and a negative value makes the zone play earlier. Because each zone has its own file, the offset applies only to that zone.
A Bluetooth speaker can be an AirPlay 2 zone like any other output, as long as PulseAudio sees it as a sink and a remap sink has been built on top of it.
  1. Pair and connect the speaker on the host with bluetoothctl (pair, trust, connect). trust lets the speaker reconnect on its own after a reboot or power cycle. Pairing keys are stored by BlueZ and survive reboots. See Pairing walkthrough below for the full steps.
  2. Confirm PulseAudio created a sink for it. pactl list sinks short | grep bluez should show something like bluez_output.AA_BB_CC_DD_EE_FF.1 (PipeWire-pulse) or bluez_sink.AA_BB_CC_DD_EE_FF.a2dp_sink (PulseAudio). If the speaker connects but no sink appears, check that its card is on the a2dp-sink profile (pactl list cards short, then pactl set-card-profile <card> a2dp-sink).
  3. Create a remap sink on top of the Bluetooth sink in the Multi-room Audio Controller addon, exactly as you would for a sound card (see Setting up a new zone).
  4. Restart this addon with the speaker connected. The zone is built from the remap sink, so it’s only generated if the Bluetooth sink and its remap sink exist at that moment.
Pairing walkthrough
Pairing happens on the Home Assistant host itself, in a shell on the machine that has the Bluetooth adapter. It is not done inside this addon. The host needs a working Bluetooth adapter with BlueZ running, and PulseAudio’s Bluetooth module (module-bluetooth-discover and module-bluez5-discover, or the PipeWire equivalent). You can confirm the modules are loaded with pactl list modules short | grep blue.
1. Open bluetoothctl and get the controller ready.
bluetoothctl
At the [bluetoothctl]> prompt:
power on
agent on
default-agent
scan on
If the controller shows up as Powered: yes and Pairable: yes, you’re ready. If power on fails, check rfkill list for a blocked adapter (sudo rfkill unblock bluetooth).
2. Put the speaker in pairing mode. This is usually a long press on its Bluetooth button until a light flashes. Make sure the speaker isn’t currently connected to a phone or another device, because a connected speaker stops advertising and won’t show up in the scan.
3. Find the speaker’s address. Watch the scan output for a line like:
[NEW] Device AA:BB:CC:DD:EE:FF Speaker Name
The AA:BB:CC:DD:EE:FF part is the speaker’s address. If the scan is noisy, run devices once it settles to list what has been seen. Pressing Tab after pair completes known addresses.
4. Pair, trust, and connect.
pair AA:BB:CC:DD:EE:FF
trust AA:BB:CC:DD:EE:FF
connect AA:BB:CC:DD:EE:FF
scan off
exit
Some speakers ask for confirmation or a PIN during pair. Answer yes to a confirmation request, or try 0000 (or 1234) for a PIN.
5. Check the result.
bluetoothctl info AA:BB:CC:DD:EE:FF | grep -E "Paired|Trusted|Connected"
You want Paired: yes, Trusted: yes, Connected: yes, and a bluez_output... or bluez_sink... entry in the sink list. The sink name contains the speaker’s address and stays the same on every connection.
If something goes wrong:
  • The speaker never appears in the scan: re-trigger pairing mode (the speaker may time out after a minute or two), disconnect it from any other device, and run scan on again.
  • org.bluez.Error.AuthenticationFailed, or pairing times out: run remove AA:BB:CC:DD:EE:FF, put the speaker back in pairing mode, and start over from scan on.
  • It pairs but connect fails (for example br-connection-profile-unavailable): PulseAudio’s Bluetooth modules probably aren’t loaded or aren’t talking to BlueZ. Check pactl list modules short | grep blue and journalctl -u bluetooth -b.
  • It connects but there’s no sink: the card may be on the wrong profile. Run pactl list cards short | grep bluez, then pactl set-card-profile <card name> a2dp-sink (older versions call it a2dp_sink).
  • The adapter’s address changes after a replug or reboot: BlueZ ties pairing keys to the adapter’s address, so a different address means the speaker has to be paired again. Compare bluetoothctl list across a reboot to check. Some inexpensive USB adapters report a default address.
For more detail on bluetoothctl and BlueZ, the Arch Linux wiki’s Bluetooth page (Bluetooth - ArchWiki) is a good general reference, and man bluetoothctl lists every command.
What happens when the speaker disconnects: many speakers drop the link after a few minutes of silence, or when powered off or out of range. The Bluetooth sink disappears, and the remap sink built on it goes with it. When the speaker reconnects, the Bluetooth sink returns but the remap sink is not recreated automatically, and the zone’s receiver is left pointing at a sink that no longer exists. Reconnect the speaker, make sure its remap sink is back, and restart this addon.
Latency and sync: Bluetooth (A2DP) adds roughly 100–250 ms of delay that AirPlay 2 doesn’t know about, so a Bluetooth zone plays late relative to the other rooms when grouped. Compensate for it with a negative latency offset in the zone’s custom configuration (see Custom general configuration per zone, above). The delay depends on the codec (SBC vs AAC, for example) and can differ slightly between connections, so re-tune if the speaker changes codec or you notice drift after a reconnect.
To measure the delay, play a click track (a short, sharp click once per second) to the Bluetooth zone and a non-Bluetooth zone at the same time and record both with your phone, standing about equidistant from the two. Zoom in on one click in an audio editor such as Audacity and measure the gap between the two onsets. Use that gap, as a negative number of seconds, as your starting offset, then re-record and adjust until the clicks merge into one.
Using and synchronizing the zones in Music Assistant
Every zone this addon creates shows up in Music Assistant (MA) as an AirPlay player. MA chooses how to stream to it by default, but you can pick the streaming mode yourself, and that choice is the key to getting reliable playback and good sync when you play to several zones at once.
1. Show the advanced settings. Open each of this addon’s players in MA and turn on Show advanced settings. The streaming mode option stays hidden until you do, so repeat it for every player you want to configure.
2. Set the streaming mode. In the player’s Configure AirPlay section, make sure Enable this protocol on this player is ticked, then choose a Streaming mode:
  • Automatic (recommended) [default]: MA picks the mode itself.
  • AirPlay 2 - PTP timing
  • AirPlay 2 - NTP timing
  • AirPlay 2 - compatibility mode
  • AirPlay 1 (RAOP)
For these zones, set the players to AirPlay 2 - compatibility mode, or use AirPlay 1 (RAOP) instead. Test a mode by playing to the zone, and by playing to a group of zones, before settling on it.
3. Play to one zone or several. Select a single player in MA to play to one zone, or group several players and play to the group to hear them together. You can also group the zones from an iPhone, iPad, or Mac with AirPlay 2’s own multi-room selection, as described at the top of this README.
MA remembers each player’s settings, including the streaming mode. Because this addon keeps each zone’s name and AirPlay 2 port stable across restarts (see Restarting), the zone comes back as the same player and keeps its settings. If you rename a zone, MA treats it as a new player and its streaming mode returns to Automatic, so set it again.
  • One AirPlay 2 zone per PulseAudio remap sink, built on shairport-sync and nqptp.
  • Cast devices on your network appear automatically as AirPlay 2 zones.
  • Per-zone custom configuration, for example a latency offset to keep a Bluetooth speaker in sync with your other rooms.
  • Bluetooth speaker and Music Assistant setup guides.
iVolt1 Home Assistant Addons
A collection of Home Assistant addons for advanced audio and home automation.
Add this repository to your Home Assistant instance.
Installation
The quickest way is the button above. To add the repository by hand:
  1. Navigate to Settings → Add-ons → Add-on Store
  2. Click the menu (⋮) in the top right and select Repositories
  3. Add the following URL:
    https://github.com/iVolt1/hassio-apps
  4. The addons will appear in the store under iVolt1 Home Assistant Addons
Addons
Turns your PulseAudio-backed audio hardware (sound cards, USB DACs, HDMI outputs, Bluetooth speakers) and your Google Cast (Chromecast/Google Home) speakers into AirPlay 2 receivers. Play to them individually or grouped from an iPhone, iPad, or Mac, or use them as players in Music Assistant.
Requires host_network and PulseAudio-backed sound hardware. See the addon’s own README for setup, troubleshooting, and the Advanced section.
Support
Found a bug or have a question? Please open an issue and include the relevant zone log from /config/shairport-sync/logs/ and the output of pactl list sinks short.
What does this do that Music Assistant doesn’t already do and more?
You really don’t understand. People don’t want to use an app - they just want to use Cast or Airplay from the streamer service’s own app. Have you tried to set up Music Assistant to play from YouTube Music?
All my speaker zones in my house are powered by Chromecast AUdios. Having Airplay 2 support on all of them helps all of the Apple folks use my system with no training, no app, and no need for anything like Music Assistant. I’m sure for the Sonos types who have a specific collection they want to play it’s fine. But most people want don’t want a new app - they just want everything to look like a speaker.
This app gives you the best of both MA and devices like iPhones that can stream directly to Airplay 2 players with the ability to easily switch back and forth. This is an important feature for guests and myself which in my case primarily play Spotify music or Radio Paradise from iPhones. Pointing guests to some MA or HA web page is not really seamless at this time but hopefully that will improve as guest access gets ironed out. The focus of the app is a little bit on multiple Airplay 2 pulse audio outputs from the sound devices on the HAOS box including remap sinks from multichannel sound cards. This was not possible until recent PRs merged to shairport-sync and nqptp that allow more than one shairport-sync instance to run on a single ip address. I have the same Airplay Devices configured in MA as described in the Readme and have an HA dashboard to control the players and sources and can switch back and forth by using one MA or the phone.
Hey I tried to install your repo but got this error : Cmd(‘git’) failed due to: exit code(128) cmdline: git clone -v --recursive --depth=1 --shallow-submodules – https://github.com/iVolt1/hassio_apps /data/apps/git/f367b2ce stderr: 'Cloning into ‘/data/apps/git/f367b2ce’… fatal: could not read Username for ‘https://github.com’: No such device or address ’
Edit: okay its because your repo is “hassio-apps” and not “hassio_apps”
Thank you for the report. I fixed the repo name as you suggested so please try again.
Is this repo offline? Wanted to make an issue
The repo is online at GitHub - iVolt1/hassio-apps: Home assistant apps · GitHub. There is a new 2.0 version available now. Thanks for the report. Here is a link to the change log since the 1.x version: hassio-apps/airplay_2_multiroom_audio/CHANGELOG.md at d8164d25eee27614474cfe540cac7e3d53f85a9e · iVolt1/hassio-apps · GitHub
