AirThings BLE Sensors with dynamic read interval?
I just implemented the Airthings BLE Sensors on an ESP32. It works very nicely.
I was even able to read two devices with one ESP32 board.
Question: there is an update_interval in the sensor, where I can set the interval, the device is queried via BLE.
Is it possible to set the update interval dynamically?
(I tried to come up with a lambda-code, but it does not work, because the update interval just does not allow templating there.)
I would like to get readings every 5min between 6:00 - 8:00 || 11:30 - 14:00 || 17:30 - 20:30.
The rest of the day 8:00 - 21:00, I would like to get readings every 30min.
During the night 21:00 - 6:00, I would like to get readings every 60min.
Goal behind all this: save battery power on the Airthings-devices.
Any ideas are very welcome.
  # Airthings Wave Plus Dachzimmer
  - platform: airthings_wave_plus
    name: '${friendly_name} Dachzimmer'
    ble_client_id: awp_Dach
    update_interval: 5min # default
    battery_update_interval: 24h # default
    temperature:
      name: "Dach Temperatur"
    radon:
    radon_long_term:
      name: "Dach Radon Long Term"
    pressure:
      name: "Dach Luftdruck"
    humidity:
      name: "Dach Feuchtigkeit"
    co2:
    tvoc:
    illuminance:
      name: "Dach ambient light"
    battery_voltage:
      name: "Dach Batterie Spannung"
  # Airthings Wave Plus Dachzimmer: Batterieanzeige in %
  - platform: copy
    source_id: awp_Dach_volt
    name: 'Dach Battery Level'
    unit_of_measurement: "%"
    device_class: battery
    accuracy_decimals: 0
    filters:
      - calibrate_linear:
        - 2.2 -> 0
        - 3.1 -> 100
